TeeChart VCL/FMX v2022 [29 SEPT 2022] RELEASE 2022.36.220929
Post by Yeray » Thu Sep 29, 2022 11:18 am
Greetings!
Steema Support Central writes to inform you of the availability of the latest TeeChart VCL/FMX 2022.36.220929 release with full RAD Studio 11 Alexandria, Update 2 (RX/DX/CX) support.
The new update includes TeeChart Pro and Standard binary and source code installers for all development environments already supported.
Customers with active subscription may download the version at no-charge from the customer download page.
If you'd like to try-out the new release you can follow this link to download the fully functional evaluation version.
Version history for TeeChart VCL/FMX may be viewed at the product release notes.
Gus
Re: TeeChart VCL/FMX v2022 [29 SEPT 2022] RELEASE 2022.36.220929
Post by Gus » Thu Sep 29, 2022 9:02 pm
I tried installing the new package, but it would not compile. It failed with the following error. Maybe not all of the files are in the package:
TeeChart Pro
Compilation started: 9/29/2022 4:47:43 PM
Win32 v28 (Delphi 11 and C++Builder 11 Update 2) (C++)
EXCEPTION:
Cannot copy file: C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\FMX_XE35\FMXTee.About.pas to C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2022.36\Source\FMX\FMXTee.About.pas
Error Code: 3 Description: The system cannot find the path specified
Post by Yeray » Fri Sep 30, 2022 7:08 am
I've been able to reproduce it. Indeed it seems to be a problem in the Sources installer.
I'm revising it.
Post by Yeray » Fri Sep 30, 2022 7:43 am
I've just uploaded the corrected installer. You can download it again.
Sorry for the inconvenience generated and thanks for reporting it.
Post by Yeray » Wed Oct 19, 2022 12:20 pm
We've just uploaded new source code installers for v2022.36 overwriting the previous ones.
The problem was the "UnicodeLangs" folder was empty.
GPwolterskluwer
Post by GPwolterskluwer » Mon Jan 16, 2023 8:35 am
I hope I am right here with my question.
I have installed the version 2022.36.220929.
In the VCL tutorial it talks about an Examples folder e.g. in tutorial 5 "See TeeChart coded Legend example in the Examples folder". Where can I find this folder?
The folder is not in my TeeChart installation directory.
Thanks a lot
Post by Yeray » Tue Jan 17, 2023 1:04 pm
I see you have TeeChart with sources so I guess you installed that. Note the sources installer comes without examples.
The source code license also gives you access to the binary installers so an option would be to install the binary version next to your source code installation.
Or you could just download the examples from the GitHub repo here.
