A way to achieve this is through the AfterDraw event (
_TChart.AfterDraw += _TChart_AfterDraw;
I set up an example for you:
private void _TChart_AfterDraw(object sender, IGraphics3D g)
// Keep in mind what PositionUnits we're using. I'm choosing Percent, adjust accordingly.
_YAxis.PositionUnits = PositionUnits.Percent;
axis1.PositionUnits = PositionUnits.Percent;
// I prefer storing the text inside the Title property, but make it invisible = false.
axis1.Title.Visible = false;
axis1.Title.Text = "Middle";
_YAxis.Title.Visible = false;
_YAxis.Title.Text = "Left";
// Add to a List if we want to use a foreach loop, definitely not needed
List<Axis> axes = new List<Axis>();
axes.Add(_YAxis);
axes.Add(axis1);
foreach(Axis axis in axes)
double xPosPercent = axis.RelativePosition;
double distance;
if (xPosPercent == 0)
// Axis is at the very left of the chart. 30 is just an example that works for this demo.
distance = 30;
distance = _TChart.Width * (xPosPercent / 100);
//Finally, place the text with g.TextOut, which offers different overloads if desired
g.TextOut((int)distance, 0, axis.Title.Text);
And this is how it would look like:
- AxisTitle1.png (25.75 KiB) Viewed 8249 times
You can find more information in our docs:
https://www.steema.com/docs/TeeChartNETTutorials.htm (Tutorial 4, "Axis Control")
If this approach doesn't work for you or if you need anything else, let me know!
Best regards,
Edu
