akshobrao
Post
by akshobrao » Tue Nov 07, 2023 2:14 pm
Visual Studio 2022
.NET Framework 4.8
Steema.TeeChart.net Version 4.2023.11.6
I am exporting a template and trying to import it back and it crashing. There are two pieces of code which seem to crash the loading of the template. First is line.Marks.FollowSeriesColor = true in the code below and the second is tChart1.Tools.Add(new Steema.TeeChart.Tools.CursorTool()); The code is below and i have commented out those two lines and it seems to work. When adding each line it crashes.
Steema.TeeChart.TChart tChart1;
tChart1 = new Steema.TeeChart.TChart();
this.Controls.Add(tChart1);
tChart1.Dock = DockStyle.Top;
InitializeChart();
tChart1.Chart.Header.Visible = true;
Line line = new Line();
line.Stairs = true;
line.VertAxis = VerticalAxis.Left;
//line.Marks.FollowSeriesColor = true;
tChart1.Series.Add(line);
//tChart1.Tools.Add(new Steema.TeeChart.Tools.CursorTool());
File.Delete("template.json");
tChart1.Export.Template.IncludeData = false;
tChart1.Export.Template.Save("template.json");
tChart1.Import.Template.Load("template.json");
tChart1.Refresh();
Post
by Marc » Wed Nov 08, 2023 7:12 am
Using your test code in a NET 4.8 project, I am unable to reproduce the problem. The template loads correctly, respecting the two code lines:
I have tested with TeeChart release 4.2023.11.6 in VSNet2019 and VSNet2022..
If you are able to send us a sample project that reproduces the issue, we'll check it for other elements/causes.
With thanks.
akshobrao
Post
by akshobrao » Wed Nov 08, 2023 1:59 pm
Hi Marc,
It seems to crash here. I have attached screenshots when running in debug mode where it crashes. I created a winforms application with these files in it. Let me know if you can reproduce it with this.
- Files.zip
- (3.29 KiB) Downloaded 2954 times
- Crash2.PNG (127.15 KiB) Viewed 29479 times
- Crash.PNG (91.32 KiB) Viewed 29479 times
Post
by Marc » Wed Nov 08, 2023 4:50 pm
Thanks you for the extra info. I can reproduce the error in a fresh project. My test project may be hanging on to a cached-package reference; I'm checking for differences and cause.
Post
by Marc » Tue Nov 14, 2023 10:02 am
As a follow-up, A fix has been applied to TeeChart code to be included with the next update release.
