c++builder How to prohibit dragging legends
Post by » Mon Jul 24, 2023 1:32 am
How to prohibit dragging legends?
Re: c++builder How to prohibit dragging legends
Post by Yeray » Mon Jul 24, 2023 7:22 am
I don't understand what do you mean. The legend isn't draggable by default.
Could you please expand?
Post by » Mon Jul 24, 2023 8:31 am
Why is it possible to drag by default?
How to prevent the legend from being dragged?
Post by Yeray » Mon Jul 24, 2023 9:34 am
Sorry but it should not be draggable by default.
Check the code and the form in your project.
Post by » Tue Jul 25, 2023 7:17 am
I found the reason。
I added a selection tool to achieve drag and drop annotation functionality。
This causes the legend to also be dragged. How to solve this problem???
Post by » Thu Jul 27, 2023 2:33 am
Does anyone answer my question???
Post by Yeray » Thu Jul 27, 2023 6:43 am
Indeed, the TAnnotationTool doesn't support dragging. However, the TRectangleTool does.
So, instead of having a TAnnotationTool and adding a TSelectorTool to add dragging support to it, you could just use a TRectangleTool.
Post by » Fri Jul 28, 2023 9:12 am
Due to requirements, I can only use Annotation. How can I prevent dragging legends?
Please provide a demo of c++builder。
Post by Yeray » Fri Jul 28, 2023 2:27 pm
You can't make the TSelectorTool not to detect the Legend. So, instead of using the TSelectorTool, I'd implement the TAnnotationTool dragging myself.
#include <VclTee.Chart.hpp>
#include <VclTee.Series.hpp>
#include <VclTee.TeeTools.hpp>
private:	// User declarations
	TChart* Chart1;
	TAnnotationTool* Annotation;
	TPoint* annotationOffset;
	bool annotationDragging;
	void __fastcall ChartMouseDown(TObject *Sender, TMouseButton Button,
								   TShiftState Shift, int X, int Y);
	void __fastcall ChartMouseMove(TObject *Sender, TShiftState Shift,
								   int X, int Y);
	void __fastcall ChartMouseUp(TObject *Sender, TMouseButton Button,
void __fastcall TForm1::FormCreate(TObject *Sender)
	Chart1 = new TChart(this);
	Chart1->Parent = this;
	Chart1->Align = alClient;
	Chart1->Color = clWhite;
	Chart1->Gradient->Visible = False;
	Chart1->Walls->Back->Color = clWhite;
	Chart1->Walls->Back->Gradient->Visible = False;
	Chart1->View3D = False;
	for (int i=0; i < 2; i++) {
	  TFastLineSeries* fastLine = new TFastLineSeries(this);
	  Chart1->AddSeries(fastLine);
	  fastLine->FillSampleValues();
	Annotation = new TAnnotationTool(this);
	Chart1->Tools->Add(Annotation);
	Annotation->Left = 100;
	Annotation->Top = 100;
	Annotation->Text = "Annotation tool";
	Chart1->OnMouseDown = ChartMouseDown;
	Chart1->OnMouseMove = ChartMouseMove;
	Chart1->OnMouseUp = ChartMouseUp;
void __fastcall TForm1::ChartMouseDown(TObject *Sender, TMouseButton Button,
	if (Annotation->Clicked(X,Y))
		annotationDragging = true;
		annotationOffset = new TPoint(X-Annotation->Left,Y-Annotation->Top);
void __fastcall TForm1::ChartMouseMove(TObject *Sender, TShiftState Shift,
									   int X, int Y)
	if ((!annotationDragging) and (Annotation->Clicked(X,Y)))
		Chart1->Cursor = crHandPoint;
		Chart1->CancelMouse = true;
	if (annotationDragging)
		Annotation->Left = X-annotationOffset->X;
		Annotation->Top = Y-annotationOffset->Y;
void __fastcall TForm1::ChartMouseUp(TObject *Sender, TMouseButton Button,
		Chart1->Zoom->Active = false;
	annotationDragging = false;
Post by » Tue Aug 01, 2023 6:46 am
How to obtain a legend pointer for the Chart1MouseUp function???
Post by Yeray » Wed Aug 02, 2023 9:11 am
You can access the Legend with Chart1->Legend. Ie:
	Chart1->Legend->Color = clRed;
Post by » Thu Aug 03, 2023 2:58 am
How to determine whether the selected item is a legend in the Chart1MouseUp function???
Post by Yeray » Thu Aug 03, 2023 6:24 am
You can check if the Legend is in a given position with the Clicked function. Ie:
	if (Chart1->Legend->Clicked(X, Y) > -1)
		Chart1->Legend->Color = clWhite;
Post by » Tue Aug 08, 2023 1:22 am
How to prevent the legend from being dragged during the chartmousemove event, as shown in the following example???
Post by Yeray » Wed Aug 23, 2023 1:57 pm
Sorry, in what example?
