dynamic property class for mutilple series
coldwind
Post by coldwind » Thu Feb 09, 2023 10:31 am
Hello:
I want to show the multiple line with user select different property.
Now I has the data like
I can't define the data Model with Class, because the property is dynamic.
How do i need to use the class, to show chart with multiple Line.
the code is which i want to realize, but it did't work.
// http receive
string response = "[{\"name\":\"aa\",\"age\":10,\"height\":170},{\"name\":\"bb\",\"age\":11,\"height\":175},{\"name\":\"cc\",\"age\":12,\"height\":180}]";
using Newtonsoft.Json;
// the response has unknowed property, so i need use object to deserialize
JArray jArray = JsonConvert.DeserializeObject<JArray>(response);
// jArray element actual class type is JObject
// when i use Add( list as IList),it not work.
void showChart(string selXLabel, List<string> selYLineLabelList)
    foreach (string item in selYLineLabelList)
    	Line line = new Line();
        line.YValues.DataMember = item;
        line.LabelMember = selXLabel;
        List<object> list = jArray.ToObject<List<object>>();
        line.Add(list as IList);
        this.tChart1.Series.Add(line);
List<string> selList = ["Age","Height"].toList()....;
showChart("Name",selList );
The data Property is unknowed,
I have use HashTable ,but it doesn't work too. The code like
List<Hashtable> list = jArray.ToObject<List<Hashtable>>();
Re: dynamic property class for mutilple series
Post by Christopher » Tue Feb 14, 2023 9:27 am
based on this example:
https://www.steema.com/support/viewtopi ... =4&t=17814
It should be easy to use LINQ to create new List<Student> and assign them to multiple series. I'll get an example together for you this morning.
coldwind
Post by coldwind » Tue Feb 14, 2023 9:58 am
Hello:
The problem I faced is the Class is unknown, so I want to use the class with Dictionary , but it does't work.
Post by Christopher » Tue Feb 14, 2023 10:10 am
you can use a class if you know the structure of the Json file—using Microsoft's System.Text.Json, the following works fine:
            var data = System.Text.Json.JsonSerializer.Deserialize<List<Student>>(response);
            var age = new Line(tChart1.Chart);
            age.YValues.DataMember = "age";
            age.LabelMember = "name";
            age.Add(data as IList);
            var height = new Line(tChart1.Chart);
            height.YValues.DataMember = "height";
            height.LabelMember = "name";
            height.Add(data as IList);
        public struct Student
            public string name { get; set; }
            public int age { get; set; }
            public int height { get; set; }
coldwind
Post by coldwind » Tue Feb 14, 2023 10:40 am
Hello:
The key problem I don't know the structure of the Json file,so i want to use the Dictionary.
Post by Christopher » Tue Feb 14, 2023 11:12 am
If you don't know the structure of the Json file, how do you know what to plot in TeeChart?
coldwind
Post by coldwind » Tue Feb 14, 2023 1:23 pm
Hello:
I need to show chart with the specificed column. before post the http request, i will appoint the column name,then i will receive the data with the specificed column.
eg. request data is
["name","age"],
response data is
[{name:"Lily",age:10},{name:"Jack",age:11}...]
eg.
request data is
["subject","score"],
response data is
[{subject:"english",score:90},{subject:"mathematics",score:99}...]
I just know the response data has the specificed key.
I want to use the code like:
 height.YValues.DataMember = requestData[1]; // score
 height.LabelMember = requestData[0]; // subject
Post by Christopher » Tue Feb 14, 2023 2:00 pm
Okay, in which case you can use code like:
            var data = JsonSerializer.Deserialize<JsonElement>(response).EnumerateArray();
            var age_data = data.SelectMany(x => x.EnumerateObject()).Where(x => x.Name == "age").Select(x => x.Value.GetInt32()).ToArray();
            var height_data = data.SelectMany(x => x.EnumerateObject()).Where(x => x.Name == "height").Select(x => x.Value.GetInt32()).ToArray();
            age.Title = "age";
            age.Add(age_data);
            height.Title = "height";
            height.Add(height_data);
Alternatively you can reconstruct the Student:
            age.Add(age_data.Select(x => new Student() { age = x }).ToList() as IList);
            height.Add(height_data.Select(x => new Student() { height = x }).ToList() as IList);
coldwind
Post by coldwind » Wed Feb 15, 2023 2:44 am
Hello:
The student class is not suitable.Then how do i add xValues to the line,when i use age.Add(xValues,yValues), I receive NullRefrenceException.
I guess the xValues is must number array, but I need use string data to XValues,like name,subject,category..
            age.Title = "age";
            age.Add(age_data);
Post by Christopher » Wed Feb 15, 2023 10:14 am
Then you can create a more suitable one.
Yes, TeeChart Series take XValues and YValues, which are numbers, and Labels, which are strings.
Maybe you can make something of code like this:
        class Request
            public string? Name { get; set; }
            public int Value { get; set; }
            public static Request Empty { get; set; } = new Request { Name = null, Value = -1 };
            List<Request> GetData(string request)
                var response = "[{\"name\":\"aa\",\"age\":10,\"height\":170},{\"name\":\"bb\",\"age\":11,\"height\":175},{\"name\":\"cc\",\"age\":12,\"height\":180}]";
                var req = JsonSerializer.Deserialize<JsonElement>(request).EnumerateArray();
                var data_nv = data.SelectMany(x => x.EnumerateObject()).Where(x => x.Name == req.First().GetString() || x.Name == req.Last().GetString()).Select(x => x.Value);
                return Enumerable.Zip(data_nv, data_nv.Skip(1), (x, y) =>
                    if (x.ValueKind == JsonValueKind.String)
                        return new Request { Name = x.GetString(), Value = y.GetInt32() };
                        return Request.Empty;
                }).Where(x => x != Request.Empty).ToList();
            age.YValues.DataMember = "Value";
            age.LabelMember = "Name";
            age.Title = "Age";
            age.LinePen.Width = 3;
            age.Add(GetData("[\"name\",\"age\"]") as IList);
            height.YValues.DataMember = "Value";
            height.LabelMember = "Name";
            height.Title = "Height";
            height.Add(GetData("[\"name\",\"height\"]") as IList);
            height.VertAxis = VerticalAxis.Right;
Screenshot from 2023-02-15 11-12-22.png (39.51 KiB) Viewed 27359 times
coldwind
Post by coldwind » Wed Feb 15, 2023 11:17 am
Hello:
The newest reply may be suitable with me,but next trouble is my data is not int,may be it's double,or float or long. I attempt to convert with object , I think TeeChart will use actual type,but it's not work.
Post by Christopher » Wed Feb 15, 2023 11:25 am
This is not really a TeeChart issue now, as TeeChart will correctly render the data you give it as long as it is either a number type or a string. Your issue now is to convert your data into one of these two formats, which should be easy to do using the JsonValueKind enum as I did in the example I gave you.
Please also be aware that we offer consultancy services by which we can write your TeeChart application for you—for more details please write to sales@steema.com.
coldwind
Post by coldwind » Wed Feb 15, 2023 12:25 pm
Hello:
Maybe you misunderstood.
the code like:
            string response = "[{\"name\":\"aa\",\"age\":10,\"height\":170.1},{\"name\":\"bb\",\"age\":11,\"height\":175.3},{\"name\":\"cc\",\"age\":12,\"height\":173.5}]";
            var data = jArray.Select(ele => {
                var jdata = (JObject)ele;
                return jdata.GetValue("age").ToObject<int>();
            }).ToArray();
            var ageData = jArray.Select(ele => {
                return jdata.GetValue("height").ToObject<object>();
            }).ToArray();
            // System.Double
            MessageBox.Show(ageData[0].GetType().ToString());
            Line line = new Line(this.tChart1.Chart);
            line.Add(data,ageData);
when i change the object to double, it's ok. But maybe it's int.
so i want to use object , and i actually get index 0 data type is System.Double , why TeeChart can't use it.
Post by Christopher » Wed Feb 15, 2023 12:31 pm
I can see again that I did understand your problem. Your problem is with Newtonsoft Json.NET. All the examples I used were using Microsoft's System.Text.Json namespace, which again is not strictly a TeeChart issue.
Again I will say that it will be perfectly possible to check for the type and convert it correctly using System.Text.Json, as I mentioned in my last message. If you need help in using either Json.NET or System.Text.Json within your TeeChart app, can I again please suggest you consider the use of our consulting services.
coldwind
Post by coldwind » Wed Feb 15, 2023 12:59 pm
Hello:
Okay, i'm Beginners with C#. I can find the decimal type, maybe is useful. I hava use System.Text.Json in my project ,but the Decimal is well in Newtonsoft.Json too.
So can i use it to convert the int or double,or long to Decimal on YValue?
Thank you Your Help.
