Marks tip doesn't work properly on overlapped points.
Amol
Post by Amol » Mon Feb 22, 2021 2:02 pm
Hi Steema,
We have used TChart.Net 2012 and created a chart with point series. In which we have plotted multiple point series and for displaying point value we have used masks tip.
When points are overlapped then marks tip does not work properly.
For your reference, we have also added a demo.
Amol
demo.rar
(63.13 KiB) Downloaded 3163 times
Amol
Re: Marks tip doesn't work properly on overlapped points.
Post by Amol » Fri Mar 05, 2021 3:32 pm
Hi Steema,
We are waiting for your valuable reply so kindly provide me the solution ASAP.
Amol
Post by Christopher » Mon Mar 08, 2021 9:05 am
attached the results I obtain:
I'm afraid I can't see where the problem you mention is occurring.
Amol
Post by Amol » Mon Mar 08, 2021 3:26 pm
Hi Steema,
I have attached a video file in which I have shown the problem of mask tip, where the points are overlapped the mask tip are flickering and is not shown complete value.
Amol
Masktip.rar
(112.05 KiB) Downloaded 3053 times
Post by Christopher » Mon Mar 08, 2021 3:31 pm
This is not the behavior I see using your project with the NuGet package you can download (or directly add to your project) from here:
https://www.nuget.org/packages/Steema.TeeChart.NET
Can you please use this assembly to see if you can reproduce the problem with it?
Amol
Post by Amol » Fri Mar 12, 2021 3:08 pm
Hi Steema,
I have used new assembly as u given, but the problem still going on. For your reference i have a video file, this video was created with new assembly.
Amol
Masktip_With_NewDLL.rar
(117.08 KiB) Downloaded 3059 times
Post by Christopher » Mon Mar 15, 2021 8:58 am
As I said in my last message, I cannot reproduce what I see in your video on my machine using the latest NuGet package and the code in your example. I suspect that the effect is an artifact of the process of video capture.
