TChartPageNavigator and High DPI
wasowerby
Re: TChartPageNavigator and High DPI
Post by wasowerby » Fri Aug 07, 2020 10:00 am
Ok Christopher, I'll try that. BTW, I edited my last msg but hadn't seen that you had already replied - doh!
Andrew
Post by Christopher » Fri Aug 07, 2020 10:19 am
Hello Andrew,
Thank you, that would be great - and no problem :)
wasowerby
Post by wasowerby » Fri Aug 07, 2020 1:36 pm
Hi Christopher,
I replied a few hours ago, but my message seems to have disappeared. Your demo works perfectly at 100% and 175% when compiled here by 10.4 with patched 1 - 3. So it looks as though there is a problem with my environment or code. Thanks for your help in progressing this issue. I'll get back to you if I find a solution.
Andrew
Post by Christopher » Fri Aug 07, 2020 1:51 pm
Hello Andrew,
I'm sorry your message disappeared, not at all sure what happened there. Glad to hear I may have been of some help, on the other hand - if you were to report back with any further news on this problem that would be greatly appreciated.
wasowerby
Post by wasowerby » Sat Aug 08, 2020 4:32 pm
Found the problem. The Chart>Axis>Left/Bottom>Labels>Size settings were 33 and 27 respectively. These were fine for 100% scaling but not for 175%; setting them both to 0 fixed the problem. I wouldn't have found this problem if I hadn't been able to compare all my properties and settings with the one's in Ed's demo! I think you still need to fix your Navigator buttons for high-DPI though.
Thanks for your help with this.
Andrew
wasowerby
Post by wasowerby » Mon Aug 10, 2020 9:29 am
However... Just noticed that, although there is now no overlapping between axis titles and labels, the axis titles now aren't scaled up at 175%! How do I fix that?
Andrew
wasowerby
Post by wasowerby » Mon Aug 10, 2020 9:42 am
Actually, measured them at 100 and 175% with a ruler and they are scaled up. So please ignore my comment.
Thanks, Andrew
