teechart JS : on hover of chart getting RangeError: Maximum call stack size exceeded
Ashutosh
Post by Ashutosh » Wed Oct 24, 2018 9:46 am
On hover of MD chart it is showing error in console " ERROR RangeError: Maximum call stack size exceeded".
Can you please suggest how to resolve it.
And on hover of MD chart we don't want to see all chart values and just want to see green lines custom info(Means title).
while Zooming how to make this color graph smooth zooming.Attached a screen shot where we are zooming using .net teechart control getting expected result.
Expected zoom.png (136.16 KiB) Viewed 50761 times
eventInfoTest.zip
(276.11 KiB) Downloaded 2597 times
Re: teechart JS : on hover of chart getting RangeError: Maximum call stack size exceeded
Post by Yeray » Fri Oct 26, 2018 1:11 pm
Regarding the RangeError, debugging your sources, I see a couple of issues:
First, you are calling your startRefresh method at the end of your redrawMdLine:
		function redrawMdLine() {
			if (isLive) {
				startRefresh();
				isLive = false;
And the startRefresh code calls the redrawMdLine function again:
		function startRefresh() {
			setInterval(redrawMdLine(), 5000);
So basically, you are creating an endless loop here. And you are adding 10 new Line series each time redrawMdLine is called, which I'm not sure if it's what you wanted to do.
Try changing the isLive flag before calling startRefresh:
			if (isLive) {
				isLive = false;
				startRefresh();
Secondly, you are reassigning the tip.old_refresh in that redrawMdLine function. And this is calling itself several times. I would just remove that part of code:
			/*tip.old_refresh = tip.refresh;
			tip.refresh = function (series, index) {
				if (series !== mdChart.series.items[0]) {
					tip.old_refresh(series, index);
I don't see titles assigned to the lines, so I'm adding them. Then, you could use the tip.ongettext to get the series title:
		function drawMD(data) {
			for (i = 0; i < lineArray.length; i++) {
				line.title = "Mean " + i;
			tip.ongettext=function(tip,text,series,index) {
				return series.title;
The example here seems to do the smoothed=false correctly.
Ashutosh
Post by Ashutosh » Tue Oct 30, 2018 9:20 am
Actually MD chart will be refresh every time and lines will be drawn in different positions. So that every time on hover of line we need to show the title. And one more thing is on hover of chart values are showing and out of chart also it is reflecting. Actually we don't need to show all the values except on hover of lines. Please give us solution like this. If any doubt, we will give clarity on that.
Ashutosh
Post by Yeray » Wed Nov 14, 2018 12:43 pm
We've discussed this through mail but if anyone else comes here and wants to know the solution to the issues exposed here we go.
That's the purpose of the ToolTip ongettext event:
That was the purpose of the redefinition of the ToolTip refresh function, to ensure the ToolTip responds to all the series in that chart except on the first one:
				else {
					tip.hide();
