TeeChart Animation
realsol
TeeChart Animation
Post by realsol » Mon Dec 04, 2017 3:48 am
I have 2 charts separated by a splitter. The bar chart lets users select months, and that months categories are displayed in the bottom pie chart.
I want to make sure the user sees that clicking on the bar does indeed change the pie. I am new to Delphi Berlin (from Delphi 5) and am new to animations. I would like to create some sort of animation that will look like the pie chart is comming from the bar chart.
Any ideas how to accomplish this or any examples I could look at.
Attached is a screenshot of the charts.
realsol
Re: TeeChart Animation
Post by realsol » Mon Dec 04, 2017 3:49 am
Also, is there a way to make the legend multiline. I would like the dates displayed in the legend on the second line of the legend item.
Post by Yeray » Mon Dec 04, 2017 8:43 am
realsol wrote:Any ideas how to accomplish this or any examples I could look at.
There are some animations shipped with TeeChart. You can see a couple of examples under "All features\Welcome !\Tools\Series Animation" in the Features Demo program shipped with the binary installation of TeeChart Pro.
Post by Yeray » Mon Dec 04, 2017 8:45 am
realsol wrote:Also, is there a way to make the legend multiline. I would like the dates displayed in the legend on the second line of the legend item.
http://bugs.teechart.net/show_bug.cgi?id=1952
realsol
Post by realsol » Mon Dec 04, 2017 9:51 pm
Thanks. I will take a look.
realsol
Post by realsol » Mon Dec 04, 2017 10:50 pm
I downloaded the demo from https://www.steema.com/downloads/vcl. It was right where you pointed me. I want to do something also with the pie chart but didn't see any examples. The problem though is there is no source code where I can see how the animation is done. Where can I find that?
Post by Yeray » Tue Dec 05, 2017 10:14 am
The demo sources are shipped with the binary installation (evaluation version included).
realsol
Post by realsol » Tue Dec 05, 2017 5:21 pm
I already have purchased and using the TeeChart Std and don't want to mess anything up with my installation. Will it, or is there a better way to get the source for the demo. Any other documentation would help.
Post by Sandra » Wed Dec 06, 2017 3:37 pm
Hello reasol,
TeeChart Std VCL/FMX doesn't support animation as you can check in TeeChart VCL/FMX Feature Matrix. Therefore, if you want work with Animation is necessary use TeeChart Pro VCL/FMX version.
Thanks in advance,
realsol
Post by realsol » Wed Dec 06, 2017 11:30 pm
You have seen my charts. My customers thought my 3D charts were dated. I tried my best to make them look more modern.
If I upgraded to the Pro version, could I take my charts (above) and make them look like this? https://vimeo.com/246186475
Post by Sandra » Thu Dec 07, 2017 12:20 pm
Hello realsol,
I have prepared for you a simple project with your request. I would like suggest you download the TeeChart Por VCL/FMX Evaluation versions from here and check if the project attached beolow works in your end.
AnimationCharts.zip
(2.22 KiB) Downloaded 3295 times
Hoping this helps
realsol
Post by realsol » Thu Dec 07, 2017 4:44 pm
Thanks. I don't want to have to uninstall my TeeChart to install the pro to test a demo, so I will assume your answer is yes to my question. But thanks you for the zip as I assume, if not now, I will be upgrading and the example will be a great starting point for me.
Thank you.
realsol
Post by realsol » Mon Dec 11, 2017 6:13 pm
I am talking to Steema about upgrading, but like I said, I don't want to have to uninstall the STD, install pro to see the tutorial. Is there a way that you could please compile this demo so I can take a look before taking the plunge to the pro.
Post by Yeray » Tue Dec 12, 2017 7:54 am
I've compiled the project Sandra attached some posts above with RAD 10.2 Tokyo and TeeChart Pro v2017.22.
Note it's a VCL project but the result shouldn't be very different in FMX.
Find attached a .7z containing the .exe.
AnimationCharts.7z
(2.14 MiB) Downloaded 2472 times
Post by Yeray » Tue Dec 12, 2017 8:26 am
Yeray wrote:Note it's a VCL project but the result shouldn't be very different in FMX.
If you are interested in FMX, you can look at the example here.
Find a compiled version of the project here.
