Problem with plotting bar graph
Innervations
Post by Innervations » Sun Oct 08, 2017 7:37 am
I am having a small issue plotting a simple bar chart.
The problem I'm having is that the first data point plotting a bar chart appears as a single line rather than a bar. Here is a link to a small video demonstrating the problem
ftp://innervations.dyndns-server.com/DO ... roblem.MP4
Here is a snippet of the source code that actually updates the TeeChart:
If Val(LabelCount.Text) > bars Then 'to stop add the same bar twice
If targetmet Then
If CheckBoxAudioFeedback.Checked Then My.Computer.Audio.Play(oversoundfile, AudioPlayMode.Background)
Bar1.Add(Val(LabelCount.Text), Val(LabelValue.Text), Color.Green)
bars = bars + 1
Else
If CheckBoxAudioFeedback.Checked Then My.Computer.Audio.Play(undersoundfile, AudioPlayMode.Background)
Bar1.Add(Val(LabelCount.Text), Val(LabelValue.Text), Color.Red)
bars = bars + 1
End If
End If
Any assistance to resolve this issue would be greatly appreciated.
Sincerely,
Rob
Re: Problem with plotting bar graph
Post by Christopher » Mon Oct 09, 2017 11:32 am
Hello Rob,
Yes, this issue was resolved in issue number 1794:
http://bugs.teechart.net/show_bug.cgi?id=1794
the resolution is present in build 4.1.2017.02140 released on 14th March 2017.
Innervations
Post by Innervations » Mon Oct 09, 2017 12:06 pm
Brilliant. Thanks Christopher. I will download and install latest TeeChart now.
Cheers
Rob
Innervations
Post by Innervations » Tue Oct 10, 2017 9:12 am
Have downloaded and installed TeeChart .NET Version 4.1.2017.2142. Install ran fine - no problem. I removed the reference to the older version and added the latest TeeChart.dll to the .NET references for my application (screen shot attached).
When I build and run my application I get the error that code generation could not load the old TeeChart.dll or one of its dependencies (screen shot attached).
Is there something else I have to change to update Visual Studio 2015 and my application to use the Version 4.1.2017.2142?
Rob
Error on running app
runtime error.jpg (42.13 KiB) Viewed 10799 times
Screen shot of application references
application references.jpg (249.02 KiB) Viewed 10799 times
Innervations
Post by Innervations » Tue Oct 10, 2017 10:02 am
Success!
I uninstalled and reinstalled the latest .NET version of TeeChart and all is working fine now.
Best Regards
Rob
