SURFACE CHART ISSUE
PIDOTECH
SURFACE CHART ISSUE
Post by PIDOTECH » Wed Sep 06, 2017 5:50 am
As I was making a surface chart, I encountered an issue with it.
I attached a file that describes the situation that I am facing.
I would like to know how I would be able to fix this issue.
Thank you for your cooperation.
Surface Chart Issue.zip
(315.45 KiB) Downloaded 879 times
Re: SURFACE CHART ISSUE
Post by Christopher » Wed Sep 06, 2017 7:31 am
Thank you for the Word document describing your issue. Would you please be so kind as to give us the data to used to generate this chart? You can easily export the data to a text file, for example, as can be seen in the Feature Demo shipped with TeeChart:
PIDOTECH
Post by PIDOTECH » Tue Sep 12, 2017 6:57 am
I would like to attach a project file to show what I meant, but I was not able to do so because of the size limitation up to 502 kb.
It would be greatly appreciated if I would be provided an e-mail address, so I can send my project file to you.
Thank you.
Post by Christopher » Tue Sep 12, 2017 7:42 am
Hello -
You can upload your files/projects to:
http://www.steema.cat/upload/
PIDOTECH
Post by PIDOTECH » Wed Sep 13, 2017 7:23 am
With userID as PIDOTECH and email as kjh0213@pidotech.com, I have sent a zip file called WindowsFormsApplication1.zip to your server.
I look forward to finding a solution for this issue.
Thank you.
Post by Christopher » Wed Sep 13, 2017 5:22 pm
Thank you for your project.
In order to confirm the extent of this issue, I have recreated your project in TeeChart Pro for VCL, the code of which is the basis of TeeChart Pro for .NET. Using the following code (for your reference):
uses
  Winapi.Windows, Winapi.Messages, System.SysUtils, System.Variants, System.Classes, Vcl.Graphics,
  Vcl.Controls, Vcl.Forms, Vcl.Dialogs, VclTee.TeeGDIPlus, VCLTee.TeEngine,
  Vcl.ExtCtrls, VCLTee.TeeProcs, VCLTee.Chart, Vcl.StdCtrls, VCLTee.TeCanvas, VCLTee.TeExport,
  VCLTee.TeePDFCanvas, VCLTee.TeeTools, VCLTee.TeeSurfa;
var bottomSurface,leftSurface:TChartAxis;
    aspect:TView3DOptions;
    surface1, surface2:TSurfaceSeries;
  procedure AddFromFile(Series:TSurfaceSeries; MyPath:String);
  var strings:TStringList;
    t:Integer;
    line:String;
    strArray  : TArray<String>;
    charArray : Array[0..0] of String;
    format:TFormatSettings;
   try
    strings := TStringList.Create;
    strings.LoadFromFile(MyPath);
    charArray[0]:=',';
    format.DecimalSeparator:='.';
    for t := 0 to strings.Count-1 do
      line:=strings[t];
      strArray:=line.Split(charArray);
      Series.AddXYZ(StrToFloat(strArray[0], format), StrToFloat(strArray[1], format), StrToFloat(strArray[2], format));
    finally
      strings.Free;
 Chart1.Tools.Add(TRotateTool);
 bottomSurface:=Chart1.Axes.Bottom;
 bottomSurface.Automatic:=false;
 bottomSurface.Maximum := 200;
 bottomSurface.Minimum := 1;
 leftSurface := Chart1.Axes.Depth;
 leftSurface.Automatic := false;
 leftSurface.Maximum := 180;
 leftSurface.Minimum := 1;
 Chart1.View3D:=true;
 Chart1.Chart3DPercent:=100;
 aspect:=Chart1.Aspect;
 aspect.Orthogonal := false;
 aspect.Elevation := 330;
 aspect.Rotation := 330;
 aspect.Zoom := 70;
 surface1:=TSurfaceSeries.Create(Self);
 surface1.IrregularGrid:=true;
 surface1.ParentChart:=Chart1;
 AddFromFile(surface1, '..\..\surface1.txt');
 surface2:=TSurfaceSeries.Create(Self);
 surface2.IrregularGrid:=true;
 surface2.ParentChart:=Chart1;
 AddFromFile(surface2, '..\..\surface2.txt');
I obtain the following Chart:
could I please ask you two questions:
1) are the shapes of the two series those that you would expect?
2) can you please confirm the overlap issue that also occurs in TeeChart for .NET?
PIDOTECH
Post by PIDOTECH » Thu Sep 14, 2017 3:45 am
1. No, these shapes are not the shapes that we want.
The series that appears to be on the top of another series should not be kind of transparent. It must entirely cover the bottom series.
2. Yes. This overlap issue happens in Steema Net.
Post by Christopher » Thu Sep 14, 2017 6:18 am
PIDOTECH wrote:1. No, these shapes are not the shapes that we want.
Okay, but to be clear - do you expect the two series to render as flat surfaces?
PIDOTECH
Post by PIDOTECH » Fri Sep 15, 2017 1:31 am
What do you mean by flat surfaces?
I would appreciate if you can explain about flat surfaces.
What I want to achieve here is that a part of one series above any part of another series must be displayed by itself meaning that any bottom part of another series must be completely hidden from the view.
Post by Christopher » Fri Sep 15, 2017 7:46 am
PIDOTECH wrote:What do you mean by flat surfaces?
By a 'flat surface' I mean a plane. In the image in my last post we can see two intersecting planes - is this how you expect your data to be represented, or do you have no clear idea of the type of surface the data represents?
PIDOTECH wrote:What I want to achieve here is that a part of one series above any part of another series must be displayed by itself meaning that any bottom part of another series must be completely hidden from the view.
Yes - unfortunately this is not going to be possible in GDI+, neither in VCL nor in .NET. The only alternative here is to use TeeChart's OpenGL canvas.
