BarChart Side by Side
realsol
Post by realsol » Wed May 31, 2017 7:05 pm
How can I keep this chart from overlapping each other? I have them set on the series to display side by side. See attached.
Re: BarChart Side by Side
Post by Sandra » Thu Jun 01, 2017 9:22 am
Hello realsol,
To do as Series are drawn side by side, you need active the BarStack propierty Side by Side. The code below shows you how can do it:
var Series1,Series2,Series3,Series4: TBarSeries;
     Series1 := TBarSeries.Create(Self);
     Series2 := TBarSeries.Create(Self);
     Series3 := TBarSeries.Create(Self);
     Series4 := TBarSeries.Create(Self);
     Chart1.AddSeries(Series1);
     Chart1.AddSeries(Series2);
     Chart1.AddSeries(Series3);
     Chart1.AddSeries(Series4);
     Series1.FillSampleValues(5);
     Series2.FillSampleValues(5);
     Series3.FillSampleValues(5);
     Series4.FillSampleValues(5);
     Series1.Marks.Visible := False;
     Series2.Marks.Visible := False;
     Series3.Marks.Visible := False;
     Series4.Marks.Visible := False;
     Series1.MultiBar := mbSide;
Hoping this helps you, otherwise don't hesistate to contact us.
Thanks in advance
realsol
Post by realsol » Thu Jun 01, 2017 2:39 pm
Sandra wrote:Hello realsol,
Thanks in advance
I had that set for the Series already in the IDE but added it in my OnCreate procedure, but it still makes no difference. What other properties might cause this?
realsol
Post by realsol » Fri Jun 02, 2017 6:21 am
Also, please see my earlier post where it was supposed to be addressed: http://www.teechart.net/support/viewtop ... 17&t=16485. In that post the did address the 'Other Slice' in the pie chart, but no word no the bar chart fix. ..
Post by Sandra » Fri Jun 02, 2017 11:32 am
Hello realsol,
We are doing many test to verify if the bug is fixed or not for next maintenance release, so I can't reproduce it using our production TeeChart Pro/VCL source code.
Thanks in advance
realsol
Post by realsol » Fri Jun 02, 2017 2:18 pm
Are there any settings I might have accidentally changed that would cause this? I think I used the basic bar chart settings but could have accidentally changed a setting that causes this. What is weird is some months print OK. Others don't.
realsol
Post by realsol » Fri Jun 02, 2017 5:18 pm
If I set View3d to false, all the bars line up like they are suppose too. Here are 3 images.
1. Chart in 3d
2. Chart without 3d
3. My chart 3d settings
Post by Sandra » Wed Jun 07, 2017 11:27 am
Hello realsol,
Sorry for the delay.
I would like inform you that the problem occurs when is set the Xvalues property Order to Descending. Therefore, as a workaround, I would suggest you set the XValues order for each series to None. The code below shows you how:
  Chart1[0].XValues.Order := loNone;
  Chart1[1].XValues.Order := loNone;
Hoping this helps you.
Thanks in advance
realsol
Post by realsol » Wed Jun 07, 2017 3:41 pm
I have 'None' already set in the ide so I added to the MainForm.OnCreate. No difference.
Also, in this situation, X is a date. Late I change the 'X' value to an integer set to 'None' and still they overlap. I hate not using 3d on my first release using your product since it looks so nice and I have a 3d chart right below it.
Any other suggestions?
Post by Yeray » Thu Jun 08, 2017 7:30 am
Try setting the Order as loAscending instead of loNone. Ie:
  Chart1[1].XValues.Order:=loAscending;
  Chart1[1].XValues.Sort;
  Chart1.Repaint;
This works in the test project in #1820
realsol
Post by realsol » Thu Jun 08, 2017 2:58 pm
I tried to add that to the end of my OnCreate method:
  DBChart2[1].XValues.Order:=loAscending;
  DBChart2[1].XValues.Sort;
  DBChart2.Repaint;
Same result as before. Again, only when printed in 3d.
realsol
Post by realsol » Thu Jun 08, 2017 3:13 pm
After looking at the code again, I figure the 'sort' is a method, thus needs values to sort, so I moved the code right after I assign the series it's values, but they still overlap.
TopQuery.Active := true;
          if DBChart2[1] <> nil then
            DBChart2.Repaint;
realsol
Post by realsol » Thu Jun 08, 2017 5:07 pm
Got it working. I needed to Sort each of the 1 to 4 Series that might be active in a for to loop.
          DBChart2[i].XValues.Order:=loAscending;
          DBChart2[i].XValues.Sort;
          DBChart2.Repaint;
Thanks for your help!
Post by Yeray » Fri Jun 09, 2017 6:38 am
Glad to hear it works fine now!
