Shift 100% Stacked Bar Graph
rpt
Post by rpt » Wed Aug 24, 2016 2:51 pm
I am trying this using designer only .
1) Is it possible to shift bar graph left ?
2) Can i remove 0 gridline ( bottom most) gridline and show 100% gridline
[img]
Amortization Graph.png (60.84 KiB) Viewed 21583 times
[/img]
Source code : https://github.com/dekajp/DealViewChart ... esigner.cs
Re: Sift 100% Stacked Bar Graph
Post by Christopher » Thu Aug 25, 2016 9:04 am
I think I can achieve what you're looking for with code like the following:
    Form1 form;
    private void button5_Click(object sender, EventArgs e)
      form = new Form1();
      form.tChart1.Axes.Bottom.SetMinMax(1, 2);
      form.tChart1.GetNextAxisLabel += TChart1_GetNextAxisLabel;
      form.ShowDialog();
    private void TChart1_GetNextAxisLabel(object sender, GetNextAxisLabelEventArgs e)
      if (((Steema.TeeChart.Axis)sender).Equals(form.tChart1.Axes.Right)) e.Stop = false;
      switch (e.LabelIndex)
        case 0: e.LabelValue = 25; break;
        case 1: e.LabelValue = 50; break;
        case 2: e.LabelValue = 75; break;
        default: e.Stop = true; break;
rpt
Re: Shift 100% Stacked Bar Graph
Post by rpt » Thu Aug 25, 2016 1:14 pm
thanks chris
This seems to be working . I see that SetMinMax doing the spacing and Event for Axis label is removing 0 value axis line.
rpt
Post by rpt » Wed Nov 30, 2016 2:43 pm
Is there a Way to get bounds of bar .
void AmortizationGraphTen_AfterDraw(object sender, Graphics3D g)
            TChart tChart1 = (TChart)sender;
            foreach (Series sbar in tChart1.Series)
                try
                    Bar bar1 = (Bar)sbar;
                    Rectangle barBound = bar1.BarBounds; // Why  always last column  ?
                    int xFirst = bar1.CalcXPos(0) ;
                    int yFirst = bar1.CalcYPos(0);
                   // How to check if this does not exists
                    int xSecond = bar1.CalcXPos(1);
                    int ySecond = bar1.CalcYPos(1);
                    Point start = new Point(xFirst + barBound.Width, yFirst);
                    Point startDown = new Point(xFirst + barBound.Width, yFirst + barBound.Height);
                    Point DownToRight = new Point(xSecond, ySecond + barBound.Height);
                    Point RightToUp = new Point(xSecond, ySecond);
                    Point UpToStart = start;
                    Point[] curvePoints = { start, startDown, DownToRight, RightToUp, start };
                    SolidBrush blueBrush = new SolidBrush(Color.Blue);
                    g.GDIplusCanvas.FillPolygon(blueBrush, curvePoints);
                    //g.MoveTo(new Point(xFirst,yFirst));
                    //g.LineTo(new Point(xSecond, ySecond),0);
                catch (Exception ex)
But How do i get Bar Bounds of First Column and Second Column for each Bar
rpt
Post by rpt » Wed Nov 30, 2016 7:26 pm
I am able to acheive what i need by deriving Bar Class. As you can see in the image. But i want to achive this in After Draw event.
Is this possible in After draw event . If No , then i would like to use TEN file and load this class. but every time i try to do . I am getting reflection error.
namespace Steema.TeeChart.Styles
    public class AmortBar : Bar
        public AmortBar()
            : base()
        Rectangle PreviousBarBound;
        public override void DrawBar(int barIndex, int startPos, int endPos)
            base.DrawBar(barIndex, startPos, endPos);
            Rectangle current;
            if (barIndex == 0)
                PreviousBarBound = this.BarBounds;
            if (barIndex == 1)
                current = this.BarBounds;
                Point start = new Point(PreviousBarBound.X +PreviousBarBound.Width, PreviousBarBound.Y);
                Point startDown = new Point(PreviousBarBound.X + PreviousBarBound.Width, PreviousBarBound.Y + PreviousBarBound.Height);
                Point DownToRight = new Point(current.X, current.Y+current.Height);
                Point RightToUp = new Point(current.X, current.Y);
                Color Soft = Color.FromArgb(80, this.Color);
                SolidBrush blueBrush = new SolidBrush(Soft);
                this.Chart.Graphics3D.GDIplusCanvas.FillPolygon(blueBrush, curvePoints);
Post by Marc » Thu Dec 01, 2016 3:32 pm
Here's a coded example.
      bar1.MultiBar = MultiBars.Stacked;
      bar1.Add(3);
      bar1.Add(4);
      bar2.Add(5);
      bar2.Add(2);
      bar3.Add(2);
      bar3.Add(3);
      bar1.BarWidthPercent = 30;
      bar2.BarWidthPercent = 30;
      bar3.BarWidthPercent = 30;
    private void tChart2_AfterDraw(object sender, Graphics3D g)
      for (int s = 0; s < tChart2.Series.Count; s++)
        Point[] poly = new Point[4];
        for (int i = 0; i < tChart2.Series[0].Count; i++)
          Bar aBar = ((Bar)tChart2[s]);
            if (i == 0)
              if (s == 0)
                poly[0] = new Point(aBar.CalcXPos(i) + aBar.BarBounds.Width, tChart2.Axes.Bottom.Position);
                poly[0] = new Point(aBar.CalcXPos(i) + aBar.BarBounds.Width, ((Bar)tChart2[s-1]).CalcYPos(i));
              poly[1] = new Point(aBar.CalcXPos(i) + aBar.BarBounds.Width, aBar.CalcYPos(i));
              poly[2] = new Point(aBar.CalcXPos(i), aBar.CalcYPos(i));
              if (s == 0)
                poly[3] = new Point(aBar.CalcXPos(i), tChart2.Axes.Bottom.Position);
                poly[3] = new Point(aBar.CalcXPos(i), ((Bar)tChart2[s - 1]).CalcYPos(i));
          g.Pen.Visible = false;
          g.Brush.Color = aBar.Color;
          g.Brush.Transparency = 50;
        g.ClipRectangle(tChart2.Chart.ChartRect); //don't paint polygon out of bounds on zooms
        g.Polygon(poly);
        g.UnClip();
rpt
Post by rpt » Thu Dec 01, 2016 7:30 pm
Thank You , this worked.
rpt
Post by rpt » Thu Jan 05, 2017 7:19 pm
marc
Can you explain me how you got the stacked graph that wide ? Below is my graph and i am using
tChart1.Axes.Bottom.SetMinMax(1,2);
I want to shift Current to right and increase the Gap in between 2 stacks like you have in above post.
Post by Christopher » Mon Jan 09, 2017 11:41 am
rpt wrote: Can you explain me how you got the stacked graph that wide ? Below is my graph and i am using
Are you using the same overload of the Series.Add() method that Marc is using in his code?
rpt
Post by rpt » Mon Jan 09, 2017 7:37 pm
I am using Ten config file.
Here is the code -
 StackedBars2.cs
https://github.com/dekajp/TeeChart-for- ... edBars2.cs
Here is the Github repo . https://github.com/dekajp/TeeChart-for- ... ms-samples
