print pie chart to PDF issue
Xin
Post by Xin » Fri Mar 25, 2016 7:23 am
we are using TeeChart (4.1.2012.9283) component in our .NET application, we use TChart.Editors.EditorUtils.ShowFormModal to invoke "Graph Print Editor" dialog thus user can print pie chart to PDF (by selecting a PDF product in printer listbox), we found the Pie chart in PDF is not shown correctly, it occurs for serveral PDF tools including FreePDF, Adobe Acrobat Pro and CutePDF.
i attached two image of how pie chart is shown in PDF.
As the error will be shown in several PDF tools, so i want to know is this a known issue, are there any ways to fix (or workaround) it?
Xin
this is problematic pie chart
this is expected pie chart
Re: print pie chart to PDF issue
Post by Christopher » Tue Mar 29, 2016 9:29 am
Hello Xin,
This issue is already registered in our issue tracking software with id=1312. Many apologies for any inconvenience this issue causes. We will look into fixing this issue before the next maintenance release.
Xin
Post by Xin » Mon Apr 18, 2016 3:12 am
Hi Christopher,
Thanks a lot for the information, now we know is an known issue.
We also want to know if there are any plans for this issue, e.g. , will it be fixed, in which release we can get the fix?
Xin
Post by Christopher » Mon Apr 18, 2016 1:55 pm
Hello Xin,
Yes, id=1332 has been fixed and will be available in the next maintenance release due out at the beginning of next month.
