Blank space issue for Candle Sticks Graph
Quant
Post by Quant » Wed Feb 18, 2015 12:27 pm
while drawing Candle Stick Graph in Teechart.Net. When datavalue is not present for particular date it shows blank space (e.g.for Saturday, Sunday and Holiday.). previously when we were using Ocx version the candlestick graph was continuous without any blank space
Kindly see the attached file
Re: Blank space issue for Candle Sticks Graph
Post by Christopher » Wed Feb 18, 2015 2:35 pm
Quant wrote:while drawing Candle Stick Graph in Teechart.Net. When datavalue is not present for particular date it shows blank space (e.g.for Saturday, Sunday and Holiday.). previously when we were using Ocx version the candlestick graph was continuous without any blank space
There is an example in the Feature Demo under:
%Program Files%\Steema Software\Steema TeeChart for .NET 201X 4.1.201X.XXXXX\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
Go to the "All Features tab" and then
Welcome !\Chart styles\Financial\Candle (OHLC)\Axis Labels no Weekends
Quant
Post by Quant » Thu Feb 19, 2015 5:14 am
Thank you for your prompt response. I already gone through that example.
But that workaround of labels will not work for me.
Post by Christopher » Thu Feb 19, 2015 9:52 am
Quant wrote:Thank you for your prompt response. I already gone through that example.
Can you please send us the code that worked correctly for you in the OCX version?
Quant
Post by Quant » Thu Feb 19, 2015 12:25 pm
TChartMain.Series(0).asCandle.AddCandle(dtTemp.ToOADate(), OpenValue, HighValue, LowValue, CloseValue, dtTemp.Date.ToString(), (uint)TeeChart.EConstants.clTeeColor);
Post by Christopher » Fri Feb 20, 2015 10:44 am
In TeeChart AX there is a property called "RemoveGaps":
This property is not present in TeeChart .NET, so I have added this property as a feature request with id=1147. In the meantime, the only option is to use the technique I have described, I'm afraid.
Quant
Post by Quant » Mon Feb 23, 2015 5:34 am
Hi Christopher,
We need the same property on urgent basis, since we can not use given workaround for our project. Using integer value in date field makes us compromise most of the user requirements. It also changes our most of the source code which is based on the ActiveX Version of TeeChart.
Please let us know when we can get this functionality.
Post by Christopher » Mon Feb 23, 2015 8:37 am
Quant wrote:Please let us know when we can get this functionality.
This property will be considered for inclusion into the next maintenance release, due out at the middle of next month.
Quant
Post by Quant » Mon Apr 20, 2015 12:31 pm
We have downloaded the latest release of .Net TeeChart, but we haven't found the resolution for this Blank Space Issue.
Please let us know where we can find the same.
Post by Christopher » Tue Apr 21, 2015 8:37 am
In the latest release notes we have:
This property can be used like this:
    Candle series1;
      series1 = new Candle(tChart1.Chart);
      Random r = new Random();
      double tmpOpen;
      double tmpClose;
      int count = 0;
      DateTime dt = DateTime.Today;
      TimeSpan ts = TimeSpan.FromDays(1);
      for (int t = 0; t < 13; t++)
        tmpOpen = r.Next(100);
        tmpClose = tmpOpen - r.Next(100);
        if (dt.DayOfWeek != DayOfWeek.Saturday & dt.DayOfWeek !=
          DayOfWeek.Sunday)
          ++count;
          series1.Add(dt, tmpOpen, tmpOpen + r.Next(50),
            tmpClose - r.Next(50), tmpClose);
        dt += ts;
    private void checkBox1_CheckedChanged(object sender, EventArgs e)
      series1.RemoveGaps = checkBox1.Checked;
Quant
Post by Quant » Fri Apr 24, 2015 9:44 am
                    Candle newSeries = new Candle();
                    newSeries.VertAxis = VerticalAxis.Right;
                    newSeries.UpCloseColor = Color.White;
                    newSeries.DownCloseColor = Color.Black;
                    newSeries.CandleWidth = 2;
                    newSeries.TreatNulls = TreatNullsStyle.Skip;
                    newSeries.Marks.Style = MarksStyles.Value;
                    newSeries.Marks.MultiLine = true;
                    newSeries.Title = "Title1";
                    for (int i = 0; i < chartObj.totalSampleValues; i++)
                        date = (DateTime)dataTable.Rows[i][0];
                        open = dataTable.Rows[i][1];
                        close = dataTable.Rows[i][2];
                        high = dataTable.Rows[i][3];
                        low = dataTable.Rows[i][4];
                        labels.Add(date.ToShortDateString());
                        closeValues.Add(close.ToString());
                        //newSeries.Add(i, open, high, low, close);
                        newSeries.Add(date, open, high, low, close);
                    //newSeries.Labels = labels;
                    newSeries.RemoveGaps = true;
                    this.tChart1.Series.Add(newSeries);
                    newSeries = (Candle)tChart1.Series[0];
We are using above code for removing blank space issues in our main project; but is shows us blank screen.
Error comes at "newSeries.RemoveGaps = true;" this line.
Note: While in sample project this feature works as expected.
Post by Christopher » Fri Apr 24, 2015 11:19 am
Without access to your data, I'm afraid I cannot reproduce your issue. Can you please modify the code snippet below so I can reproduce your issue here?
    Candle newSeries;
      DateTime date = DateTime.Today;
      double open, close, high, low;
      Random rnd = new Random();
      for (int i = 0; i < 20; i++)
        date = date.AddDays(1);
        open = rnd.NextDouble();
        high = open + rnd.NextDouble();
        close = high - rnd.NextDouble();
        low = close - rnd.NextDouble();
        //labels.Add(date.ToShortDateString());
        //closeValues.Add(close.ToString());
        if (date.DayOfWeek != DayOfWeek.Saturday & date.DayOfWeek !=
          DayOfWeek.Sunday)
      newSeries.RemoveGaps = !newSeries.RemoveGaps;
Quant
Post by Quant » Fri Apr 24, 2015 11:40 am
We are using a DataTable with Following Fields
1] Date
2] Open
3] Close
4] High
5] Low
Quant
Post by Quant » Thu Jun 25, 2015 12:25 pm
Our problem still continues with series.RemoveGaps property. It shows blank screen when set to "true".
Post by Christopher » Fri Jun 26, 2015 7:48 am
Quant wrote:Our problem still continues with series.RemoveGaps property. It shows blank screen when set to "true".
As per the instructions for posting in this forum, which you can read here, can you please provide a Short, Self Contained, Correct (Compilable), Example (explanation here) with which we can reproduce your problem.
Thank you.
