[repost] How to draw 3D chart?
hi~ I'm Woon
i want to draw 3D Chart.
but i don't know how to draw chart.
i have not any reference of teechart .
so i want to example source.
i draw to 3D graph about the image pixel value
if 3 Points is (x = 0, y = 5, z = 7), (x = 2, y = 3, z = 10), (x = 4, y = 1, z = 3)
i wish to draw 3D bar Graph that x, y Axis is bottom Plane, and z Axis is Value.
is that possible?
i will wait to your answer.
thank you.
is that possible?
thank you.
- Guru
Re: How to draw 3D chart?
Hello Woon.
%Program Files%\Steema Software\Steema TeeChart for .NET 2014 4.1.2014.05090
There are many example of how to use TeeChart you can see by running TeeChartNetExamples.exe, which is under this folder:
%Program Files%\Steema Software\Steema TeeChart for .NET 2014 4.1.2014.05090\Examples\DemoProject\bin\ExecutableDemo
You should have TeeChart installed on your machine in a location similar to this one:Woon wrote:hi~ I'm Woon
hi~ I'm woon.
thank you for your answer
Now, i used to TeeChart8ActiveX.
i can find this folder
C:\Program Files\Steema Software\TeeChart Pro v8 ActiveX Control\Examples
but i can't find 3D Chart Examples.
so i want to get the Examples from you.
- Guru
Hello Woon,
I have moved your post to the ActiveX forum where the ActiveX team will be happy to answer your questions.
Re: [repost] How to draw 3D chart?
Hello Woon,
have you looked at the Bar 3D examples you can find into the TeeChartFeatures Demo, which is included into the TeeChart ActiveX installer ?
You can find them at : All Features -> Welcome -> Chart Styles -> Other -> Bar 3D.
Please take a look at the examples and if you still need help on this let us know.
Pep Jorge
http://support.steema.com
hi~ i'm woon.
Sorry, I can't find the TeeChartFeatures Demo.
i installed TeeChart from the file which is downloaded the download page of your website.
and i attached three picture files that i want to draw using TeeChart.
is that possible?
if you have check that, I am enormously grateful to you.
is that possible?
- 3d bar2.JPG (12.75 KiB) Viewed 34847 times
- 3d bar1.JPG (36.54 KiB) Viewed 34851 times
- 3d bar.JPG (55.78 KiB) Viewed 34849 times
Hello Woon,
with the TeeChart ActiveX and VB code you could make use of the Tower Series Chart and then change its aspect (orthogonal, zoom, rotated, 3dpercent, axis..). A simple example could be :
TeeCommander1.Chart = TChart1
With TChart1
.AddSeries scTower
.Series(0).asTower.AddXYZ 0, 5, 7, "", clTeeColor
.Series(0).asTower.AddXYZ 2, 3, 10, "", clTeeColor
.Series(0).asTower.AddXYZ 4, 1, 3, "", clTeeColor
.Aspect.Chart3DPercent = 100
.Aspect.Orthogonal = False
End With
Pep Jorge
hi~
Thank you for your answer.
Now I use to C++.
I try to change from VB Code to C++ Code, but I failed
So I need C++ sample code.
Now I use to C++.
Hello Woon,
vc++ code should be something like :
m_chart.AddSeries(44); // tower
m_chart.Series(0).GetasTower().AddXYZ(0, 5, 7, "", clTeeColor);
m_chart.Series(0).GetasTower().AddXYZ(2, 3, 10, "", clTeeColor);
m_chart.Series(0).GetasTower().AddXYZ(4, 1, 3, "", clTeeColor);
m_chart.GetAspect().setChart3DPercent (100);
m_chart.GetAspect().setOrthogonal(False);
Pep Jorge
Hi ~
I have a mistake. sorry.
I just have Setting of Teechart in OnInitDialog() that is my mistake.
but Now, i know how to use TeeChart. I call a event fuction after then Teechart is drawed.
I'm sorry to bother you. Thank you.
great ! I'm glat to hear all is working fine now.
Do not hesitate to contact us in the case we can be of any further help.
Pep Jorge
