I create line series added in legend with checkbox and title in left axis using custom axes. When all series or few series are selected, the relevant left axis titles are shown as expected i.e. only the titles of the selected series. But when all series are unselected, all the left axis titles are displayed (see the attached screens copy). Could you help me to avoid this?
Many thanks in advance.
Pascal
(Teechart2013.ocx is in use)
Left axis titles displayed but all series unchecked
- TChart 2013 - Legend with checkbox.zip
- (354.8 KiB) Downloaded 1158 times
Re: Left axis titles displayed but all series unchecked
Hi Pascal,
You could implement some logic in the OnClickLegend event to hide all the axes when no series is visible. For example, this seems to work fine for me here:
Here it is the rest of the code I used to test the above:
Private Sub TChart1_OnClickLegend(ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
Dim showAxes As Boolean
showAxes = False
Dim i As Integer
For i = 0 To TChart1.SeriesCount - 1
If TChart1.Series(i).Active Then
showAxes = True
Exit For
End If
Next i
For i = 0 To TChart1.Axis.CustomCount - 1
TChart1.Axis.Custom(i).Visible = showAxes
Next i
TChart1.Aspect.View3D = False
TChart1.Panel.MarginLeft = 7
Dim i, nSeries As Integer
nSeries = 4
For i = 0 To nSeries - 1
TChart1.AddSeries scLine
TChart1.Series(i).FillSampleValues 5
TChart1.Series(i).VerticalAxisCustom = TChart1.Axis.AddCustom(False)
With TChart1.Axis.Custom(i)
.AxisPen.Color = TChart1.Series(i).Color
.Title.Caption = "Custom " & Str$(i)
.Title.Angle = 90
.Title.Font.Color = TChart1.Series(i).Color
.PositionUnits = puPixels
.StartPosition = i * 100 / nSeries
.EndPosition = (i + 1) * 100 / nSeries
End With
Next i
Thank you for this nice answer. What about using this event callback with VS C++ ?
FYI, we use some events in the following way:
but I can't find where this code comes from.
Pascal
BEGIN_EVENTSINK_MAP(CResult, CDialog)
//{{AFX_EVENTSINK_MAP(CResult)
ON_EVENT(CResult, IDC_TCHART1, 37 /* OnMarkTipToolGetText */, OnMarkTipToolGetTextTchart1, VTS_I4 VTS_PBSTR)
ON_EVENT(CResult, IDC_TCHART1, 19 /* OnMouseDown */, OnMouseDownTchart, VTS_I4 VTS_I4 VTS_I4 VTS_I4)
ON_EVENT(CResult, IDC_TCHART1, 21 /* OnMouseUp */, OnMouseUpTchart, VTS_I4 VTS_I4 VTS_I4 VTS_I4)
ON_EVENT(CResult, IDC_TCHART1, 201 /* OnMouseEnterSeries */, OnMouseEnterSeriesTchart1, VTS_I4)
ON_EVENT(CResult, IDC_TCHART1, 202 /* OnMouseLeaveSeries */, OnMouseLeaveSeriesTchart1, VTS_I4)
ON_EVENT(CResult, IDC_TCHART1, 20 /* OnMouseMove */, OnMouseMoveTchart1, VTS_I4 VTS_I4 VTS_I4)
//}}AFX_EVENTSINK_MAP
END_EVENTSINK_MAP()
Pascal
Hello Pascal,
The easiest way to achieve add Event using VS c++ is adding Event OnClickLegend in design time following next steps:
1.- Open Design time dialog and select the Chart.
2.- Click with right button and choose Events
3.- Select OnClickLegend event and add it.
4.- After do it, event is created automatically and added in the code.
The code should be similar as next:
I hope will helps.
// TestLabelsC6Dlg.cpp : implementation file
#include "stdafx.h"
#include "TestLabelsC6.h"
#include "TestLabelsC6Dlg.h"
#include "panel.h"
#include "series.h"
#include "axes.h"
#include "axis.h"
#include "TeeChartDefines.h"
#include "aspect.h"
#include "zoom.h"
#include "scroll.h"
#include "environment.h"
#include "marks.h"
#include "page.h"
#include "lineseries.h"
#include "fastlineseries.h"
#include "surfaceseries.h"
#include "colorgridseries.h"
#include "mappolygon.h"
#include "mapseries.h"
#include "mappolygonlist.h"
#include "axisarrowtool.h"
#include "toollist.h"
#include "tools.h"
#include "legendpalettetool.h"
#include "comutil.h"
#include "afxdisp.h"
#include "pen.h"
#include "legend.h"
#include "legendsymbol.h"
#include "marksitem.h"
#include "pointarray.h"
#include "teepoint2d.h"
#include "strings.h"
#include "chartaxispen.h"
#include "axistitle.h"
#include "teefont.h"
#ifdef _DEBUG
#define new DEBUG_NEW
#undef THIS_FILE
static char THIS_FILE[] = __FILE__;
#endif
// CAboutDlg dialog used for App About
class CAboutDlg : public CDialog
public:
CAboutDlg();
// Dialog Data
//{{AFX_DATA(CAboutDlg)
enum { IDD = IDD_ABOUTBOX };
//}}AFX_DATA
// ClassWizard generated virtual function overrides
//{{AFX_VIRTUAL(CAboutDlg)
protected:
virtual void DoDataExchange(CDataExchange* pDX); // DDX/DDV support
//}}AFX_VIRTUAL
// Implementation
protected:
//{{AFX_MSG(CAboutDlg)
//}}AFX_MSG
DECLARE_MESSAGE_MAP()
CAboutDlg::CAboutDlg() : CDialog(CAboutDlg::IDD)
//{{AFX_DATA_INIT(CAboutDlg)
//}}AFX_DATA_INIT
void CAboutDlg::DoDataExchange(CDataExchange* pDX)
CDialog::DoDataExchange(pDX);
//{{AFX_DATA_MAP(CAboutDlg)
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CAboutDlg, CDialog)
//{{AFX_MSG_MAP(CAboutDlg)
// No message handlers
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CTestLabelsC6Dlg dialog
CTestLabelsC6Dlg::CTestLabelsC6Dlg(CWnd* pParent /*=NULL*/)
: CDialog(CTestLabelsC6Dlg::IDD, pParent)
//{{AFX_DATA_INIT(CTestLabelsC6Dlg)
// NOTE: the ClassWizard will add member initialization here
//}}AFX_DATA_INIT
// Note that LoadIcon does not require a subsequent DestroyIcon in Win32
m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
void CTestLabelsC6Dlg::DoDataExchange(CDataExchange* pDX)
//{{AFX_DATA_MAP(CTestLabelsC6Dlg)
DDX_Control(pDX, IDC_BUTTON1, m_button1);
DDX_Control(pDX, IDC_TCHART1, m_tChart1);
DDX_Control(pDX, IDC_TEECOMMANDER1, m_TCommander);
//}}AFX_DATA_MAP
BEGIN_MESSAGE_MAP(CTestLabelsC6Dlg, CDialog)
//{{AFX_MSG_MAP(CTestLabelsC6Dlg)
ON_WM_SYSCOMMAND()
ON_WM_PAINT()
ON_WM_QUERYDRAGICON()
ON_BN_CLICKED(IDC_BUTTON1, OnButton1)
//}}AFX_MSG_MAP
END_MESSAGE_MAP()
// CTestLabelsC6Dlg message handlers
BOOL CTestLabelsC6Dlg::OnInitDialog()
CDialog::OnInitDialog();
// Add "About..." menu item to system menu.
// IDM_ABOUTBOX must be in the system command range.
ASSERT((IDM_ABOUTBOX & 0xFFF0) == IDM_ABOUTBOX);
ASSERT(IDM_ABOUTBOX < 0xF000);
CMenu* pSysMenu = GetSystemMenu(FALSE);
if (pSysMenu != NULL)
CString strAboutMenu;
strAboutMenu.LoadString(IDS_ABOUTBOX);
if (!strAboutMenu.IsEmpty())
pSysMenu->AppendMenu(MF_SEPARATOR);
pSysMenu->AppendMenu(MF_STRING, IDM_ABOUTBOX, strAboutMenu);
// Set the icon for this dialog. The framework does this automatically
// when the application's main window is not a dialog
SetIcon(m_hIcon, TRUE); // Set big icon
SetIcon(m_hIcon, FALSE); // Set small icon
// TODO: Add extra initialization here
m_tChart1.ClearChart();
m_tChart1.GetAspect().SetView3D(FALSE);
m_tChart1.GetPanel().SetMarginLeft(7);
m_tChart1.GetLegend().SetCheckBoxes(TRUE);
int i,nSeries;
nSeries=4;
for(i=0; i<nSeries; i++)
m_tChart1.AddSeries(scLine);
m_tChart1.Series(i).FillSampleValues(5);
m_tChart1.Series(i).SetVerticalAxisCustom(m_tChart1.GetAxis().AddCustom(FALSE));
m_tChart1.GetAxis().GetCustom(i).GetAxisPen().SetColor(m_tChart1.Series(i).GetColor());
m_tChart1.GetAxis().GetCustom(i).GetTitle().SetCaption("Custom");
m_tChart1.GetAxis().GetCustom(i).GetTitle().SetAngle(90);
m_tChart1.GetAxis().GetCustom(i).GetTitle().GetFont().SetColor(m_tChart1.Series(i).GetColor());
m_tChart1.GetAxis().GetCustom(i).SetPositionUnits(puPixels);
m_tChart1.GetAxis().GetCustom(i).SetStartPosition(i * 100 / nSeries);
m_tChart1.GetAxis().GetCustom(i).SetEndPosition((i + 1) * 100 / nSeries);
return TRUE; // return TRUE unless you set the focus to a control
void CTestLabelsC6Dlg::OnSysCommand(UINT nID, LPARAM lParam)
if ((nID & 0xFFF0) == IDM_ABOUTBOX)
CAboutDlg dlgAbout;
dlgAbout.DoModal();
CDialog::OnSysCommand(nID, lParam);
// If you add a minimize button to your dialog, you will need the code below
// to draw the icon. For MFC applications using the document/view model,
// this is automatically done for you by the framework.
void CTestLabelsC6Dlg::OnPaint()
if (IsIconic())
CPaintDC dc(this); // device context for painting
SendMessage(WM_ICONERASEBKGND, (WPARAM) dc.GetSafeHdc(), 0);
// Center icon in client rectangle
int cxIcon = GetSystemMetrics(SM_CXICON);
int cyIcon = GetSystemMetrics(SM_CYICON);
CRect rect;
GetClientRect(&rect);
int x = (rect.Width() - cxIcon + 1) / 2;
int y = (rect.Height() - cyIcon + 1) / 2;
// Draw the icon
dc.DrawIcon(x, y, m_hIcon);
CDialog::OnPaint();
// The system calls this to obtain the cursor to display while the user drags
// the minimized window.
HCURSOR CTestLabelsC6Dlg::OnQueryDragIcon()
return (HCURSOR) m_hIcon;
void CTestLabelsC6Dlg::OnButton1()
// TODO: Add your control notification handler code here
//long i = m_tChart1.Series(0);
m_tChart1.ShowEditor(0);
BEGIN_EVENTSINK_MAP(CTestLabelsC6Dlg, CDialog)
//{{AFX_EVENTSINK_MAP(CTestLabelsC6Dlg)
ON_EVENT(CTestLabelsC6Dlg, IDC_TCHART1, 6 /* OnClickLegend */, OnOnClickLegendTchart1, VTS_I4 VTS_I4 VTS_I4 VTS_I4)
ON_EVENT(CTestLabelsC6Dlg, IDC_TCHART1, 253 /* OnAddSeries */, OnOnAddSeriesTchart1, VTS_I4)
END_EVENTSINK_MAP()
void CTestLabelsC6Dlg::OnOnClickLegendTchart1(long Button, long Shift, long X, long Y)
bool showAxes=FALSE;
int i;
for(i=0; i<m_tChart1.GetSeriesCount(); i++)
if(m_tChart1.Series(i).GetActive())
showAxes=TRUE;
for(i=0; i<m_tChart1.GetAxis().GetCustomCount(); i++)
m_tChart1.GetAxis().GetCustom(i).SetVisible(showAxes);
Hi Sandra,
Thank you for this nice help. I feel I got all what I need.
Have a great day.
Best regards,
Pascal
Have a great day.
Best regards,
Pascal
