"Stairs" line series with null points is not drawn correctly
jhameenniemi
Post by jhameenniemi » Mon Apr 29, 2013 7:07 am
TeeChart 2012.0.0.9 ActiveX component. Line series with "stairs" option selected and null point in series to cut line. First line section AFTER null point from (x.1, y.1) to (x.2, y.2) is not drawn correctly (x.1, y.1 -> x.2, y.1 -> x.2, y.2) but using y value BEFORE null point i.e. (x.1, y.1 -> x.2, y.-1 -> x.2, y.2). Pictures of a sampe data and the resulting line series attached.
TeeChart 2012 3.jpg (120.83 KiB) Viewed 10927 times
TeeChart 2012 1.jpg (25.8 KiB) Viewed 10926 times
Re: "Stairs" line series with null points is not drawn correctly
Post by Sandra » Mon Apr 29, 2013 10:35 am
Hello
I suggest you see next code, so it works in correct way for me using latest version Activex( v2012.0.0.9 ).
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
With TChart1.Series(0)
.AddXY DateTime.TimeValue("13:35.40"), 4.072, "", vbBlack
.AddXY DateTime.TimeValue("13:35.51"), 3.79, "", vbBlack
.AddXY DateTime.TimeValue("13:36.02"), 3.79, "", vbBlack
.AddXY DateTime.TimeValue("13:36.24"), 4.134, "", vbBlack
.AddXY DateTime.TimeValue("13:36.28"), 3.161, "", vbBlack
.AddXY DateTime.TimeValue("13:36.40"), 4.086, "", vbBlack
.AddXY DateTime.TimeValue("13:36.51"), 4.086, "", vbBlack
 End With
TChart1.Series(0).asLine.Stairs = True
TChart1.Series(0).SetNull 3
TChart1.Axis.Bottom.Labels.DateTimeFormat = "hh.mm.ss"
Could you tell us if previous code works in your end?
I hope will helps.
Post by Yeray » Mon Apr 29, 2013 12:40 pm
jhameenniemi wrote:Line series with "stairs" option selected and null point in series to cut line
Maybe you meant FastLine series?
jhameenniemi
Post by jhameenniemi » Tue Apr 30, 2013 6:54 am
Sorry, I should have been more specific. Yeray, you are correct... the series is a FastLine series with "TreatNulls" property set to "Don't Paint" and "Stairs" property set to "TRUE".
We are using C++ here's a code to reproduce the problem:
	m_wndChart.GetAspect().SetView3D(FALSE);
	long seriesIndex = m_wndChart.AddSeries(scFastLine);
	CSeries& series = m_wndChart.Series(seriesIndex);
	series.AddXY(TimeToDateTime("13:35.40"), 4.072, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:35.51"), 3.79, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:36.02"), 3.79, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:36.24"), 4.134, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:36.28"), 3.161, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:36.40"), 4.086, "", RGB(0, 0, 0));
	series.AddXY(TimeToDateTime("13:36.51"), 4.086, "", RGB(0, 0, 0));
	series.GetAsFastLine().SetStairs(TRUE);
	series.GetAsFastLine().SetTreatNulls(tnDontPaint);
	series.GetXValues().SetDateTime(true);
	series.SetNull(3);
	m_wndChart.GetAxis().GetBottom().GetLabels().SetDateTimeFormat("hh.mm.ss");
Line is not drawn correctly. We did not have this problem with TeeChart ActiveX 8 with the same code.
Post by Yeray » Tue Apr 30, 2013 9:01 am
I found a fix for it (TV52016561). The next maintenance release will include it.
