XE3 FMX TeeChart Performance
brian
Post by brian » Tue Nov 20, 2012 2:53 am
Dear,
Performance issues
I use Delphi 7 and TeeChart CPU load of 1 to 2%,
But Delphi XE3 and TeeChart CPU load of 10 to 11%,
I in the development of the stock software requires a lot of quick updates
How to solve the CPU load problem?
and Chart.Endupdate no response
EX,
Timer1.Interval := 250;
procedure TForm1.Timer1Timer(Sender: TObject);
var i: Integer;
// Chart1.BeginUpdate;
// series1.BeginUpdate;
series1.Clear;
for i := 0 to 1000 do
Series1.Add(i);
// series1.EndUpdate;
// Chart1.EndUpdate;
Brian.
Re: XE3 FMX TeeChart Performance
Post by Narcís » Tue Nov 20, 2012 9:10 am
Hi Brian,
This works fine for me here using attached project. Can you please check if it solves the issue at your end? You may also be interested in following the recomendations at the Real-time Charting article here.
FastLineFMX.zip
(1.26 KiB) Downloaded 1274 times
brian
Post by brian » Wed Nov 21, 2012 1:51 am
I've been using your example code, but the CPU is still 10 to 12%
Is XE3's performance issues?
Post by Narcís » Wed Nov 21, 2012 11:17 am
Hi brian,
According to the tests we have run here, Firemonkey applications are slower than VCL applications, that could be an important difference. For me, the project I attached, stays at about 2-3% CPU usage. Have you tried that in different machines? Does the application uses the same CPU rate in all of them? Have you found performance differences in non-TeeChart related applications?
