Last Installer for XE3 does not work
dfpost
Re: Last Installer for XE3 does not work
Post by dfpost » Wed Nov 07, 2012 5:42 am
MINAS wrote:
what to do now ?
You are don't make backup files with standart version TeeChart.
MINAS
Post by MINAS » Wed Nov 07, 2012 6:12 am
the installer asked me 3 times
do you want to ..... ?
3 times i press yes ...
dfpost
Post by dfpost » Wed Nov 07, 2012 7:02 am
Move the file Tee9170.bpl from XE3 bin folder to temporary folder.
Post by Yeray » Wed Nov 07, 2012 9:30 am
dfpost wrote:I can't activate online the release version TeeChart2012SourceCode.exe after download.
I've reset your license counter. Try it again.
Post by Yeray » Wed Nov 07, 2012 9:35 am
Hi again,
MINAS wrote:after installing the latest version on Delphi Pro XE,
i start Delphi and i get the message
what to do now ?
It seems the TeeChart Standard packages that come with the IDE (Tee9170) are still being loaded when the IDE starts. You should be able to fix it simply unselecting these packages in the packages list in the IDE. Once you'll be sure there's no TeeChart Standard package selected in the list (and no 3rd party tool package that may be using it selected), you should be able to select the TeeChart Pro packages in the same list.
dfpost
Post by dfpost » Wed Nov 07, 2012 10:20 am
The binary version Build 2012.07.121105 installed successfully. But after installation showed this message:
westy
Post by westy » Thu Nov 08, 2012 7:00 am
I too just go this message. I started a new thread without realising a few other users were having the same issue.
I am on Win 7 Pro 64 bit SP1.
Cheers,
Westy
Post by Yeray » Thu Nov 08, 2012 9:46 am
dfpost wrote:The binary version Build 2012.07.121105 installed successfully. But after installation showed this message:
That's strange.
Anybody else with this problem?
westy wrote:I too just go this message. I started a new thread without realising a few other users were having the same issue.
Looking at the other thread, I understand you reproduce the problem that was initially reported in this thread, not the problem dfpost has just reported. Isn't it?
dfpost
Post by dfpost » Tue Nov 13, 2012 7:55 am
This message is not displayed if you are installing on a computer that is not yet installed TeeChart.
Post by Yeray » Tue Nov 13, 2012 3:00 pm
dfpost wrote:This message is not displayed if you are installing on a computer that is not yet installed TeeChart.
I'm not sure to understand you. What should you have installed before installing TeeChart v2012.07 binary on XE3 to get that error? Could you please list the exact instructions we should follow to reproduce the problem here?
dfpost
Post by dfpost » Wed Nov 21, 2012 6:09 pm
Hi.
  • 1. Install TeeChart2012SourceCode.exe Build 2012.07.121031.
  • 2. Uninstall TeeChart2012SourceCode.exe Build 2012.07.121031.
  • 3. Install TeeChart2012RADXE3.exe Build 2012.07.121105.
Post by Narcís » Thu Nov 22, 2012 8:22 am
Hi dfost,
Thanks for your feedback. Could you reproduce it with the 2012.07.121105 build of the source code installer?
