Floating point overflow zooming in
I have a chart comprising a TAreaSeries and some TLineSeries. After a number of successful zoom-in operations without unzooming, I get 'floating point overflow'. Is this something to do with the chart being unable to calculate a tick increment? Is there a way to anticipate the error?
Trevor Cooper
Trevor Cooper
Re: Floating point overflow zooming in
Hi Trevor,
I've attached a an example project. If you keep zooming then the error will occur sooner or later, usually somewhere between the 3rd and 15th zoom. Sometimes zooming where there's no data seems to produce the error sooner. I know it seems unlikely that a user would usefully zoom in 15 times, but sometimes they do when they're looking for miniscule changes of data.
This is running TeeChart Pro v2012.06.120613 32-bit VCL in Delphi 2007.
Hope you can repdocue the error.
Trevor Cooper
Trevor Cooper
- FloatingPointOverflowOnZoom.zip
- (2.91 KiB) Downloaded 1803 times
Hi Trevor,
Thanks for the project. I could reproduce the problem with it. I simplified it to the minimum so the smallest code I found that still reproduces the problem is this:
It seems the combination of 2D, an inverted bottom axis and a TLineSeries with XValues.Order set to loNone gives this problem.
I've added it to the defect list to be further investigated (TV52016351).
uses Series;
with Chart1 do
View3D:=False;
Axes.Bottom.Inverted:=True;
with Chart1.AddSeries(TLineSeries) as TLineSeries do
XValues.Order := loNone;
FillSampleValues;
Hi Trevor,
We've just reviewed and fixed it for the next maintenance release (TV52016351).
Thanks Yeray.
When's the next maintenance release?
In the meantime, it doesn't seem possible to trap the error, and when it occurs the default unzoom behaviour no longer works, so users have to rebuild the chart. If you know the fix, then do you also know whether there is an obvious way of predicting when the problem will occur so we can anticipate it by preventing 'too many' zooms?
Trevor Cooper
Trevor Cooper
Hi Trevor,
I'm afraid I can't tell you when the next maintenance release will be published. You can see the release notes to have an idea on how often we use to do it.Toreba wrote:When's the next maintenance release?
The easier workaround I see right now would be to create a custom series inheriting from TLineSeries and overriding the DrawValue method to prevent it:Toreba wrote:In the meantime, it doesn't seem possible to trap the error, and when it occurs the default unzoom behaviour no longer works, so users have to rebuild the chart. If you know the fix, then do you also know whether there is an obvious way of predicting when the problem will occur so we can anticipate it by preventing 'too many' zooms?
uses Series;
{ MySeries }
type
MySeries = class(TLineSeries)
protected
procedure DrawValue(ValueIndex:Integer); override;
procedure MySeries.DrawValue(ValueIndex: Integer);
var XPos: Integer;
XPos:=CalcXPos(ValueIndex);
if (XPos<$7FFF) and (XPos>-$7FFF) then
inherited;
{ TForm1 }
with Chart1 do
View3D:=False;
with Chart1.AddSeries(MySeries) as MySeries do
FillSampleValues;
Yeray,
Yes, that works, thank you very much. The software now doesn't crash, but at one point during the sequence of zooms the chart plot area fills with grey and no series are visible, but we can zoom or unzoom out of that and continue working with the chart as normal. I think we can live with that quite happily until the next maintenance release.
Thanks for your help.
Trevor Cooper
Trevor Cooper
Hi Trevor,
I zoom several times and there's no error message and I can't see this effect. Could you please send us some screenshot so we can see where are you exactly zooming in?
I'm not sure to be able to reproduce this. I've taken your project, removed the 3 TLineSeries and added the same code, but at runtime, to be able to substitute them for MySeries type. Here is the code:Toreba wrote:The software now doesn't crash, but at one point during the sequence of zooms the chart plot area fills with grey and no series are visible, but we can zoom or unzoom out of that and continue working with the chart as normal. I think we can live with that quite happily until the next maintenance release.
{ MySeries }
protected
TForm1 = class(TForm)
ChartEditor1: TChartEditor;
Chart1: TChart;
procedure Chart1DblClick(Sender: TObject);
procedure FormShow(Sender: TObject);
private
public
var
Form1: TForm1;
Series3: TAreaSeries;
Series2: MySeries;
Series1: MySeries;
Series4: MySeries;
implementation
{$R *.dfm}
procedure TForm1.Chart1DblClick(Sender: TObject);
Self.ChartEditor1.Execute;
Series3:=Chart1.AddSeries(TAreaSeries) as TAreaSeries;
with Series3 as TAreaSeries do
Marks.Arrow.Visible := True;
Marks.Callout.Brush.Color := clBlack;
Marks.Callout.Arrow.Visible := True;
Marks.Visible := False;
SeriesColor := clSilver;
Title := 'Invert Level';
AreaLinesPen.Color := clGray;
AreaLinesPen.Style := psDashDot;
DrawArea := True;
Pointer.InflateMargins := True;
Pointer.Style := psRectangle;
Pointer.Visible := False;
XValues.Name := 'X';
XValues.Order := loAscending;
YValues.Name := 'Y';
YValues.Order := loNone;
Series2:=Chart1.AddSeries(MySeries) as MySeries;
with Series2 as MySeries do
SeriesColor := clBlue;
Title := 'Hydraulic Level';
LinePen.Color := clBlue;
LinePen.Width := 2;
Series1:=Chart1.AddSeries(MySeries) as MySeries;
with Series1 as MySeries do
Title := 'Energy Level';
LinePen.Color := clRed;
LinePen.Width := 2;
Series4:=Chart1.AddSeries(MySeries) as MySeries;
with Series4 as MySeries do
Title := 'Soffit Level';
LinePen.Color := clGreen;
Series1.FillSampleValues(10);
Series2.FillSampleValues(10);
Series3.FillSampleValues(10);
Series4.FillSampleValues(10);
var XPos: Integer;
inherited;
Yeray,
I modified my oroginal project accroding to your suggested workround, as attached. If you maximise the form, zoom in far enough, say somewhere between the 10th and 25th zooms, then the plot area goes grey as in the attached image, but there's no error and you can still zoom in and out at this stage.
But, the greying out only occurs if the form is maximised. Otherwise all is fine.
I hope that makes sense to you.
Trevor Cooper
Trevor Cooper
- (23.92 KiB) Downloaded 1900 times
But I'm not sure where are you exactly zooming. Note there are zones where you will see everything on gray in just one zoom (if you zoom into the area series).
Please, show us a video, or post an example with hardcoded values and hardcoded zoom rectangles to be sure we are doing exactly the same.
Yeray,
I've slightly expanded my example project with a hard-coded set-up of series values, and a memo showing the last zoomed coordinates. If I had more time today I'd hard code these zoom coordinates for you. If I concentrate on zooming in the top left part of the chart, and keep going,I get a greying out of the plot area after about eight zooms. I attach the project with screen captures of start and end of the process.
Hope that helps.
Trevor Cooper
Hope that helps.
Trevor Cooper
- (80.97 KiB) Downloaded 2058 times
I could reproduce the issue now thanks to your project.
Simplifying it to the minimum, indeed, it seems to be completely different issue:
I've observed it seems to depend on the height the chart actually has. The problem is reproducible when the window is maximized, but also if you don't maximize the window and you resize it to have big height.
I've added it to the wish list to be investigated (TV52016366).
uses Series;
var i: integer;
Chart1.Align:=alClient;
Chart1.View3D:=false;
with Chart1.AddSeries(TAreaSeries) do
for i:=1 to 10 do
AddXY(i, 15-i);
Chart1.Axes.Bottom.SetMinMax(9.105085051, 9.105129839);
Chart1.Axes.Left.SetMinMax(17.090535587, 17.090594192);
Self.WindowState:=wsMaximized;
Okay, thanks for your help Yeray!
