Dear Sir/Madam,
Greetings!
I am using TeeChart for .Net v3 and I would like to plot something like the image attached which is an Excel Pivot Chart.
Could you please give me an example how I can do that (including the X-Axis lables)?
Rgds,
tangone
Pivot Chart Like for TeeChart
- PivotChart.png (37.82 KiB) Viewed 21047 times
Re: Pivot Chart Like for TeeChart
Anybody got any idea on this?
Hello tangone,
We are working with this, but would be very helpful if you can send me your data to make the test.
Hi Sandra,
Glad to hear that it is being worked out.
Please see attached image (I was not allowed to upload Excel file by the way) for the sample.
Year LINE_CD OUT_QTY PLAN_QTY
Y2006 HA01 100 200
HA02 50 150
HA03 300 232
HA04 89 288
HA05 232 328
HA06 132 32
Y2007 HA01 38 188
HA02 27 132
HA03 119 172
HA04 382 121
HA05 177 232
HA06 183 48
Y2008 HA01 48 98
HA02 59 181
HA03 290 32
HA04 188 48
HA05 172 188
HA06 127 23
- Sample.png (77.64 KiB) Viewed 20957 times
Hi tangone,
You can compress it in a zip package and attach it to the forums.Please see attached image (I was not allowed to upload Excel file by the way) for the sample.
Thanks, Narcís.
Please see attached.
- Sample.zip
- (9.04 KiB) Downloaded 1511 times
Hello tangone,
Sorry for the delay. I have made a simple code where reproduce the chart you want achieve, using your data in two xml files and DataSet. Please, check if my project works as you expect. On the other hand, we have find some information as you do to made Pivot Charts using c# and I recommend you take a look in this link.
I hope will helps.
I hope will helps.
Hi Sandra,
Thanks for the sample provided, and I am sorry that I did not mention I wanted to have it in web application.
Would it be difficult to convert it to web application?
Hello tangone,
On the other hand, I have forgotten tell you as you have other option to achieve a simple pivot charts, you only need use CrossTab component of TeeChart, you can find an example, in Demo project All Features\Welcome !\Datasets\CrossTab Charts
Isn't dificult, you can take a look in our tutorials, concretly in Tutorial9 - ASP.NET Applications or in Demo ASP.Net that is installed with TeeChartFor.Net.Thanks for the sample provided, and I am sorry that I did not mention I wanted to have it in web application.
