TeeChart Speed on IOS
rlebbar
Post by rlebbar » Wed Mar 14, 2012 11:04 am
Hi Narcis,
I need your help again.
I have read and applied the "Real-time Charting article" and it did not solve the speed problem.
In fact i compared the loading time : "No optimization VS Optimization" the difference in my case is around 10 ms.
Then i noticed that the problem is not at all in loading the data!
In fact i have the feeling that the CPU is tremendously used !.
When i press a button on the same form as the TChart it responds but after a very long period of time : 10 Seconds Just to show a "Hello" message !.
Then, since i can not debug in the Mac side, i tried to debug In windows side ( where there is no speed problem at all !) .
By putting a showmessage on BeforeDraw and on AfterDraw i noticed that drawing keeps get called every time, as soon as you move the mouse, consuming CPU which is ok on windows but not on ios. Please note that no data has been modified or a form resized, just moving the mouse !
I hope that you can find a workaround to not let the TChart be redrawed unnecessarily !
r.lebbar
Re: TeeChart Speed on IOS
Post by Yeray » Wed Mar 14, 2012 1:02 pm
Hi r.lebbar,
rlebbar wrote:By putting a showmessage on BeforeDraw and on AfterDraw i noticed that drawing keeps get called every time, as soon as you move the mouse, consuming CPU which is ok on windows but not on ios. Please note that no data has been modified or a form resized, just moving the mouse !
I'm trying to reproduce this in XE2 and the actual sources in a Win7 x64 machine but it seems to work fine for me here. Find attached the application I'm using.
iOS test.zip
(3.62 KiB) Downloaded 2005 times
When the application starts, I see a call to both OnBeforeDrawChart and OnAfterDraw events but not when I move the mouse over the chart once it is shown.
rlebbar
Post by rlebbar » Wed Mar 14, 2012 2:18 pm
Hi Yeray
Please look at this image !
Your Project
Post by Yeray » Wed Mar 14, 2012 2:59 pm
Hi r.lebbar,
This is not just moving the mouse over the chart but pressing the left mouse button down and then moving the mouse to draw the zoom rectangle, isn't it?
To draw the zoom rectangle, the chart has to be redrawn.
rlebbar
Post by rlebbar » Wed Mar 14, 2012 3:17 pm
Hi Yeray
Sorry Yeray, This is JUST MOVING THE MOUSE over the chart : No Click, No left Button, No Right Button !
rlebbar
Post by rlebbar » Wed Mar 14, 2012 3:41 pm
Hi Yeray
I have not noticed a rectangle in the back that stays active
Please find the exe i have generated with your code
iOS test.zip
(3.62 KiB) Downloaded 1864 times
rlebbar
Post by rlebbar » Wed Mar 14, 2012 3:48 pm
Hi Yearay
The Exe Project was not allowed to be uploaded.
Post by Narcís » Wed Mar 14, 2012 3:50 pm
If compressing it in a zip/rar package doesn't fit in the maximum upload size (512 kb) please upload it at http://www.steema.net/upload/.
rlebbar
Post by rlebbar » Wed Mar 14, 2012 3:59 pm
Hi Narcis,
I have uploaded the exe file as indicated.
Please in the mean time what about the ios device, since i am more interested in the ios than the windows projects
Post by Yeray » Thu Mar 15, 2012 12:57 pm
Hi r.lebbar,
I'm still a little bit confused.
- The exe you sent us responds to me as I'd expect: before the first time the chart is going to be shows, both events are fired once. Then, once the chart is shown, I can move the window and move the mouse over the chart without clicking on it, and the events aren't fired. Only if I click on the chart, then it is redrawn and the events are fired again and again as I move the mouse because it needs to draw the zoom rectangle.
- In a real device, "moving the mouse over the chart without clicking on it" has no sense (at least I don't see it). So, if you are moving the finger around the chart *touching the chart*, the equivalent in windows would be clicking on the chart and moving the mouse. Then, as said above, by default, a zoom rectangle is being drawn and thus the charts is resized each time a mouse/finger displacement is being detected to draw a new zoom rectangle.
Try disabling the zoom feature:
Chart1.AllowZoom:=false;
rlebbar
Post by rlebbar » Sun Mar 18, 2012 11:51 pm
Hi yeray
Sorry for the delay, i was out of town.
Please find a sample that will show you exactly what is happening
In my case then variable "NbreOfTimesTheChartIsDrawn" increments by 5 or 6 at each hit !
r.lebbar
Test.zip
(4.26 KiB) Downloaded 1893 times
Post by Yeray » Mon Mar 19, 2012 3:36 pm
Hi r.lebbar,
Interesting. If I click on the button with the mouse it behaves as you describe (increments by 5 or 6 at each hit). But if I press the space bar (after one click with the mouse so the focus is in the button), the NbreOfTimesTheChartIsDrawn remains stable.
And the same happens if I use the chart Clicked event:
procedure TForm1.Chart1Click(Sender: TObject);
  ShowMessageFmt('So far, the Chart has been drawn %d Times',[NbreOfTimesTheChartIsDrawn]);
Could you please confirm with this the number of times the chart is drawn seems to be stable?
It would indicate that clicking the button makes the chart to be redrawn
rlebbar
Post by rlebbar » Mon Mar 19, 2012 5:49 pm
Hi Yeray
The OnChartClick seems to be more stable than the SpeedButtonClick.
But as you may notice when you click on the chart the very first time it gets redrawn once more (only the first click).
With the SpeedButtonClick it is worst since the Chart is redrawn more than 5 Times at each click.
Could you please help me get a very basic workaround since in my case there is no reason to let the chart be redrawn once the OnAfterDraw event is hit. So the question is how to freeze the chart ? (Not allowing it to be redrawn).
r.lebbar
Post by Yeray » Tue Mar 20, 2012 10:28 am
Hi r.lebbar,
TButton is also stable. It actually seems to be a non related TeeChart problem: if you remove the chart and use the Form OnPaint event instead of the chart OnBeforeDrawChart/OnAfterDraw events, it behaves exactly the same:
procedure TForm1.FormPaint(Sender: TObject; Canvas: TCanvas;
  const ARect: TRectF);
  Inc(NbreOfTimesTheChartIsDrawn);
I've opened a ticket in Embarcadero's Quality Central. You can vote for it.
http://qc.embarcadero.com/wc/qcmain.aspx?d=104281
In the meanwhile I'd suggest you to use TButton instead of TSpeedButton.
rlebbar
Post by rlebbar » Fri Mar 23, 2012 9:42 am
Hi Yeray
Thanks for your help, I have finally a decent loading time !
By using a Private variable fIsAlreadyDrawn in the Form, one can do :
procedure TFChart.TestChartAfterDraw(Sender: TObject);
fIsAlreadyDrawn := True;
procedure TFChart.TestChartBeforeDrawChart(Sender: TObject);
if fIsAlreadyDrawn Then Abort
This works on Windows but not on the real IOS device.
Then I added a property variable IsAlreadyDrawn to the Chart in the FMI code.
It drops by arround 50% the necessary time to load the chart .
I know that this is just a workaround until a real solution is found.
Many Thanks.
r.lebbar
