.asContour.Smoothing.Interpolate
lilo
Post by lilo » Tue Sep 27, 2011 11:17 am
In Active X I could set .asContour.Smoothing.Interpolate = True. Is there a similar property in net?
Re: .asContour.Smoothing.Interpolate
Post by Sandra » Wed Sep 28, 2011 9:18 am
Hello lilo,
The same property doesn't exist of TeeChart.Net tub I think you can do something as demo example All Features\Welcome !\Chart styles\Extended\Surface\Surface Smoothing. If you have any problems please let me know.
lilo
Post by lilo » Wed Sep 28, 2011 2:16 pm
If I set smoothingmode=antialias, the contour map shows white grid lines?
Post by Narcís » Wed Sep 28, 2011 2:25 pm
Hi lilo,
This is the same you already found here. The demo example Sandra pointed you doesn't involve setting SmoothingMode to AntiAlias.
JAV
Post by JAV » Fri Dec 13, 2013 3:19 pm
Hi
i need help
I have an array x y z, in this case 5 x 3 and I need to fill the grid in order my xyz array become a 25 x 3 array.
With this data i will use contour series
How can this could be done? I was checking algorithms as krigin
Does any teechart series use this kind of algorithms internally or I have to code it myself??
thank you very much
X y z
315.701,71 10.007.962 1.208.436,06
315.228,63 10.005.982 879.188,01
315.475,68 10.004.046 454.767,41
315.223,28 10.011.989 289.782,90
315.151,89 10.009.025 1.021.705,63
316.032,10 10.007.262 722.650,00
316.328,09 10.006.589 385.410,89
315.942,78 10.008.456 693.138,34
315.075,00 10.008.046 1.280.880,53
315.043,80 10.004.155 813.032,91
here is my x y z array
Post by Christopher » Mon Dec 16, 2013 3:55 pm
I have already tried to answer this question here:
http://www.teechart.net/support/viewtop ... 655#p64204
