Display values on mouse move
Petar
Post by Petar » Tue Dec 07, 2010 10:49 am
is it possible to display values for all series on mouse move as shown in the example below?
We would like to have on mouse move :
1. On left axe: highlighted values for each curve
2. On bottom axe highlighted value for the date
3. Dots on series to show where the mouse is
Petar
Re: Display values on mouse move
Post by Narcís » Tue Dec 07, 2010 11:19 am
Hi Petar,
Yes, this is possible using interpolation as in this example:
Option Explicit
Dim XCursorValue As Double
    TChart1.Aspect.View3D = False
    TChart1.AddSeries scLine
    TChart1.Tools.Add tcCursor
    TChart1.Tools.Items(0).asTeeCursor.FollowMouse = True
    TChart1.Tools.Items(0).asTeeCursor.Style = cssVertical
    Dim i As Integer
    For i = 0 To TChart1.SeriesCount - 1
        TChart1.Series(i).FillSampleValues (i + 1) * 20
    Next
Function InterpolateSeries(ByVal SeriesIndex As Long, XValue As Double) As Double
    InterpolateSeries = InterpolateLineSeries(SeriesIndex, TChart1.Series(SeriesIndex).FirstValueIndex, TChart1.Series(SeriesIndex).LastValueIndex, XValue)
End Function
Function InterpolateLineSeries(ByVal SeriesIndex As Long, FirstIndex As Integer, LastIndex As Integer, XValue As Double) As Double
  Dim index As Integer
  Dim dx, dy, val As Double
  index = FirstIndex
  Do While ((TChart1.Series(SeriesIndex).XValues.Value(index) <= XValue) And (index < LastIndex))
    index = index + 1
  Loop
  ' safeguard
  If (index < 1) Then
    index = 1
  ElseIf (index >= TChart1.Series(SeriesIndex).Count) Then
    index = TChart1.Series(SeriesIndex).Count - 1
  End If
  ' y=(y2-y1)/(x2-x1)*(x-x1)+y1
  dx = TChart1.Series(SeriesIndex).XValues.Value(index) - TChart1.Series(SeriesIndex).XValues.Value(index - 1)
  dy = TChart1.Series(SeriesIndex).YValues.Value(index) - TChart1.Series(SeriesIndex).YValues.Value(index - 1)
  If (dx <> 0) Then
    InterpolateLineSeries = dy * (XValue - TChart1.Series(SeriesIndex).XValues.Value(index - 1)) / dx + TChart1.Series(SeriesIndex).YValues.Value(index - 1)
  Else
    InterpolateLineSeries = 0
  End If
End Function
Private Sub TChart1_OnCursorToolChange(ByVal Tool As Long, ByVal X As Long, ByVal y As Long, ByVal XVal As Double, ByVal YVal As Double, ByVal Series As Long, ByVal ValueIndex As Long)
    XCursorValue = XVal
    TChart1.Header.Text.Clear
    Dim i As Integer
        TChart1.Header.Text.Add ("Series" + CStr(i) + ": Y(" + CStr(XVal) + ")= " + _
                 CStr(InterpolateLineSeries(i, TChart1.Series(i).FirstValueIndex, TChart1.Series(i).LastValueIndex, XVal)))
    Next
    Dim xs, ys, i As Integer
    xs = TChart1.Axis.Bottom.CalcXPosValue(XCursorValue)
        ys = TChart1.Axis.Left.CalcYPosValue(InterpolateSeries(i, XCursorValue))
        TChart1.Canvas.Brush.Color = TChart1.Series(i).Color
        TChart1.Canvas.Ellipse xs - 4, ys - 4, xs + 4, ys + 4
    Next
Petar
Post by Petar » Tue Dec 07, 2010 11:40 am
Thanks Narcis,
this is perfect for the dots part. Is it possible now to highlight values directly on the left and the bottom axis.
Petar
guilz2010
Post by guilz2010 » Tue Dec 07, 2010 2:27 pm
Hi Narcis,
This method works fine but there is some performances issue with a large number of points (>3000 points) :?
Is it possible to improve it especially when we move mouse cursor on the right part of the bottom axis ?
Thanks for your help :wink:
Guilz
Post by Narcís » Tue Dec 07, 2010 3:37 pm
Hi Guilz,
Yes, highlighting could be done using Annotation tools, for example:
Option Explicit
    Dim i As Integer
        TChart1.Tools.Add tcAnnotate 'one annotation for each series
    Next
    TChart1.Tools.Add tcAnnotate 'one annotation for X values.
End Function
    index = FirstIndex
      index = index + 1
    Loop
    ' safeguard
    If (index < 1) Then
      index = 1
    End If
    If (dx <> 0) Then
    Else
    End If
End Function
    XCursorValue = XVal
    Dim i As Integer
    Next
    Dim xs, ys, y, i As Integer
        y = InterpolateSeries(i, XCursorValue)
        ys = TChart1.Axis.Left.CalcYPosValue(y)
        With TChart1.Tools.Items(i + 1).asAnnotation
            .Text = Format(y, "0.00")
            .Shape.Color = vbRed
            .Shape.CustomPosition = True
            .Shape.Left = TChart1.Axis.Left.Position - 40
            .Shape.Top = ys - 10
        End With
    Next
    With TChart1.Tools.Items(4).asAnnotation
        .Text = Format(XCursorValue, "0.00")
        .Shape.Left = xs - 10
        .Shape.Top = TChart1.Axis.Bottom.Position + 10
    End With
Regarding the performance issue, the problem is that interpolation is calculated from first visible point in the series and loops through all the points in the series. Hence it takes longer the further the point is from the origin. Some optimization could be done in the InterpolateLineSeries so that loop doesn't go through all point in the series.
Petar
Post by Petar » Tue Dec 07, 2010 3:50 pm
Thank you Narcis,
that's exactly what we were looking for. Extremely useful.
Petar
guilz2010
Post by guilz2010 » Tue Dec 07, 2010 4:30 pm
Yes. I tried to use the code bellow to optimize the InterpolateLineSeries method (loop is now starting near the mouse position and not from the FirstValueIndex)
Private Sub TChart1_OnMouseMove(ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
    firstIndex = TChart1.Axis.Bottom.CalcPosPoint(X)
It's seem to work fine
Thanks a lot for your help :D
Guilz
