Layout Questions
Cartegraph
Layout Questions
Post by Cartegraph » Wed Oct 27, 2010 9:10 pm
I have a two layout Questions. The first is I have a bar graph, screen capture of it is attached call bar graph. The data and labels are getting cut off by the edge of the controls. How do I get the bar graph to stay within the control size. My tchart control in embedded in an active X report.
My second question is regarding a pie chart. A screen capture is attached called pie chart. The data labels are over lapping one another. Is there a way to make them place in free sapce instead of overtop of one another?
Pie chart.png (31.54 KiB) Viewed 12598 times
bar graph.png (8.36 KiB) Viewed 12561 times
Re: Layout Questions
Post by Narcís » Thu Oct 28, 2010 12:57 pm
Hi Cartergraph,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
You could try doing something as Pep suggested here. This a TeeChart for .NET thread but the same could apply to the ActiveX version.
Cartegraph
Post by Cartegraph » Thu Oct 28, 2010 9:16 pm
Attached is a .Net Visual studio project displaying the problem with the grid and labels being cut off.
I also attached the exe for the mini project incase you can't open the visual studio n2010 project.
I will try the coded suggestion for the overlapping callouts, I guess I just expected the control to be able to handle that.
VisualStudioProjectShowingCutOffGrid.zip
(440.61 KiB) Downloaded 628 times
ReleaseExeShowingCutOffGrid.zip
(211.2 KiB) Downloaded 651 times
Cartegraph
Post by Cartegraph » Thu Oct 28, 2010 9:49 pm
I tried the coded solution for the overlapping labels and unfornutaly i am in VBS with the contorl inside a report and i don't have acces to the porperties used in that fix. Any other suggestions?
Post by Narcís » Tue Nov 02, 2010 10:10 am
Hi Elizabeth,
If labels are cut off by chart axes/walls you can use this:
            axTChart1.Series(0).Marks.Clip = false;
However, in your examples they are cut off by chart dimensions. In that case the only solution I can think of also is using custom marks position to plot them at a slightly different location, for example:
http://www.teechart.net/support/viewtop ... s+position
Are those missing properties available outside a report? If so the only solution I can think of is drawing the chart outside the report, export it to an image and use that image into the report.
Cartegraph
Post by Cartegraph » Wed Nov 03, 2010 4:53 pm
you are right the clip setting did not work.
When i tried the code, where it drills down into the postions (Marks.Positions.Position(ii).Custom = True & .Marks.Positions.Position(ii).LeftTop.Y = yValue), thsoe values could not be evalued and i get an unknown exception. I got a simailr error when i tried to re-write the code in c# in the sample project in .Net.
As a side note, the compiler would not allow me to call the InternalRepaint giving the error message: "Only assignment, call, increment, decrement, and new object expressions can be used as a statement"
Cartegraph
Post by Cartegraph » Wed Nov 03, 2010 4:59 pm
What's interesting is that if i add a title with Text and the Left axis to visible, nothing gets cut off. The problem is my designer does not want a left axis or a title. Are there other properties i need to set to support that?
Post by Narcís » Thu Nov 04, 2010 8:17 am
Hi Cartergraph,
Try callin InternalRepaint with parenthesis, like this:
axTChart1.Environment.InternalRepaint();
If the problem persists please attach a simple example project we can run "as-is" to reproduce the problem here.
Cartegraph
Post by Cartegraph » Wed Nov 10, 2010 2:31 pm
Any suggestions on the data that is getting cut off?
Post by Narcís » Wed Nov 10, 2010 2:59 pm
Hi Cartergraph,
You could try increasing axes MinimumOffset and MaximumOffset.
