Including GridBand Tool
uptime
Post by uptime » Mon Sep 27, 2010 3:33 pm
I'm trying to add the GridBand Tool to a VBScript, but the docs show examples for visual basic. Here's the code I have:
HTML (object within a table cell):
<object id="TChart1" CODEBASE="/chart/teechart7.cab#Version=7,0,0,0" TYPE="application/x-oleobject" width="100%" height="100%" classid="CLSID:FAB9B41C-87D6-474D-AB7E-F07D78F2422E" ></object>
within VBScript tag
Sub Window_onload()
With TChart1
    .AddSeries scBar
    .Series(0).FillSampleValues 6
    .Tools.Add tcGridBand
    With .Tools.Items(0).asGridBand
        .Axis = TChart1.Axis.Left
        .Band1.Color = 16250354
        .Band2.Color = 16116201
    End With
End With
When I run this code, I get an access violation by IE 8.0.7600 and crashes the browser with message "Access violation at address 504F6CB8 in module 'teechart7.ocx'. Read of address 0000015A". Which seems to come from the ".Axis = TChart1.Axis.Left" line. Omitting that gives "Unexpected call to method or property access.".
I suspect that I haven't added the GridBand properly to the chart. Does anyone know how to add a the GridBand tool to a chart within VBScript? or any tool for that matter?
Thanks in advance!
Re: Including GridBand Tool
Post by Narcís » Wed Sep 29, 2010 9:31 am
Hi uptime,
Problem could be that you are using TChart1.Axis.Left within a With TChart1 clause, try using this:
        .Axis = .Axis.Left
uptime
Post by uptime » Wed Sep 29, 2010 12:53 pm
Thanks for your suggestion Narcís.
After making that change I'm getting this: Object required: 'Axis'
Also I noticed that it added the Cursor tool (maybe it was added by default because GridBand Tool in vbScript it's not called 'tcGridBand'?)
Can anyone post an example HTML page with a chart with GridBand Tool using vbScript?
Post by Narcís » Thu Sep 30, 2010 12:02 pm
Hi uptime,
Find attached a VBScript working example with your code.
GridBandASP.zip
(1.99 KiB) Downloaded 776 times
uptime
Post by uptime » Thu Sep 30, 2010 1:32 pm
Hello Narcis thank you for your response.
Unfortunately I need this to be all in HTML and vbScript (no ASP).
I was able to come up with a trimmed down html page as a better example:
<html><head><title>GridBand chart</title></head>
<body>
<script language="VBScript">
Sub Window_onload()
With TChart0
    .AddSeries scBar
        .Axis = .Axis.Left
    End With
End With
</script>
<object id="TChart0" CODEBASE="teechart7.cab#Version=7,0,0,0" TYPE="application/x-oleobject" width="100%" height="100%" classid="CLSID:FAB9B41C-87D6-474D-AB7E-F07D78F2422E" ></object>
</html>
If you take this code, you will see an error from Line 11 "Object required: 'Axis'" and also there is a Cursor tool added. I also attached a screenshot to show the Cursor on the chart.
Post by Narcís » Wed Oct 06, 2010 11:27 am
Hello uptime,
You need to do as in the code snippet below as some constants might not be defined.
    <body>
    Sub Window_onload()
    With TChart0
        .AddSeries scBar
        .Tools.Add 16 'tcGridBand
            .Axis = 0 'aLeft
        End With
    End With
    </script>
    <object id="TChart0" CODEBASE="teechart7.cab" TYPE="application/x-oleobject" width="100%" height="100%" classid="CLSID:FAB9B41C-87D6-474D-AB7E-F07D78F2422E" ></object>
    </html>
uptime
Post by uptime » Thu Oct 07, 2010 4:18 pm
Yes that worked!
Thank you very much Narcis for all your feedback. It's very much appreciated :)
