Bar chart query.
TonyVSUK
Bar chart query.
Post by TonyVSUK » Tue Oct 05, 2010 7:34 pm
Can someone try the VB code below?
The first bar has a X value of "0", but appears on the plot at approximately -3. What is going on?
Private Sub DrawBar()
Dim i As Long
TChart1.RemoveAllSeries
For i = 0 To 5
    TChart1.AddSeries scBar
    TChart1.Series(i).AddXY i, i * 2, "", TChart1.Series(i).Color
Next i
Re: Bar chart query.
Post by Narcís » Wed Oct 06, 2010 10:07 am
Hi Tony,
I'm afraid this is a bug I have added to the defect list (TV52015189) to be fixed.
TonyVSUK
Post by TonyVSUK » Wed Oct 06, 2010 10:12 am
Any idea when? I have customers waiting.
Post by Narcís » Wed Oct 06, 2010 10:17 am
Hi Tony,
I can't give you an estimate date for now but this is a high-priority item in the list.
Post by Narcís » Wed Oct 06, 2010 11:20 am
Hi Tony,
Thinking a little bit further about this issue, the stacking algorithm will work correctly *only* if all series have the same number of points and point x values coincide. If this is not the case, you'll have to use AddNullXY method to add "missing points". I'd use the following approach:
1) Make a list of all available (pool) of x values.
2) For individual series, cycle through (1) and use AddXY if point (x,y) exists and AddNullXY if specific point (x,y) does not exist for this series.
An easier alternative is setting MultiBar to mbNone, for example:
    Dim i As Long
    For i = 0 To 5
        TChart1.Series(i).asBar.MultiBar = mbNone
        TChart1.Series(i).asBar.BarWidthPercent = 20
    Next i
So we have closed the issue in the bug list.
TonyVSUK
Post by TonyVSUK » Wed Oct 06, 2010 11:38 am
Are you serious? How can anyone possibly make use of a chart component where the axes are not labelled correctly?
There are two series types now that do not label the axes correctly (gantt and bar).
This is a really serious bug.
Post by Narcís » Wed Oct 06, 2010 1:01 pm
Hi Tony,
This is how stacked series are designed. For stacking to work you need to have same number of points in all series and all of them should have same X values. Setting Multibar to mbNone doesn't label series wrongly but it may be nicer in 2D. There are 2 options here:
1. Set MultiBar to none and the chart to 2D view:
    Dim i As Long
    TChart1.Aspect.View3D = False
    For i = 0 To 5
    Next i
2. Add same X values for all series setting to null the points which should not be displayed in the chart.
    Dim i As Long
    For i = 0 To 5
        For j = 0 To 5
            TChart1.Series(i).AddXY j, i * 2, "", TChart1.Series(i).Color
            If i <> j Then
                TChart1.Series(i).SetNull j
            End If
        Next
    Next i
TonyVSUK
Post by TonyVSUK » Wed Oct 06, 2010 1:13 pm
My original query is not related to stacking in any way. It's basic code to draw some bars, and the x axis labels are completely wrong.
I don't want stacked series in this case, I just want the axis labelled correctly.
Post by Narcís » Wed Oct 06, 2010 1:19 pm
Hi Tony,
Yes, I understand but by default Bar series are set to MultiBar = mbSide. That's why I'm saying that if you are using several bar series the way you are you should either set MultiBar to mbNone or add null values where necessary. Actually, the example you sent would be easier using one single bar series, you can already have a different color for each series:
    Dim i As Long
    TChart1.Series(0).asBar.BarWidthPercent = 20
    TChart1.Series(0).ColorEachPoint = True
    For i = 0 To 5
        TChart1.Series(0).AddXY i, i * 2, "", clTeeColor
    Next i
Post by Narcís » Wed Oct 06, 2010 1:46 pm
Hi Tony,
Another option is setting Multibar to mbSideAll:
  Dim i As Integer
  For i = 0 To 5
    TChart1.Series(i).asBar.MultiBar = mbSideAll
  Next i
