Graph height issue
roger
Graph height issue
Post by roger » Tue Oct 05, 2010 9:19 am
We are using TeeChart Pro Activex Control v7 and also tested the functionality with TeeChart Pro v8 ActiveX evaluation version.
I am getting problem that when the series is continuously getting plotted the graph size increases momentarily and then reduces to normal.
YOu can view this in the following pictures,
I found an similar issue in TF02013500.
Is there any reason why is this happening. And could you suggest some solution or workaround for this?
INITIAL GRAPH
INCREASED SIZE
Thanks for your help,
roger
Re: Graph height issue
Post by roger » Wed Oct 06, 2010 6:58 am
Please help me!!!
Post by Narcís » Wed Oct 06, 2010 10:00 am
Hi roger,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
