RemoveSeries Issue
Guilz
RemoveSeries Issue
Post by Guilz » Wed Aug 18, 2010 1:25 pm
I would like to know if RemoveSeries method is the only method to delete specific serie on Chart ?
When i use RemoveSeries(1) method on my chart (5 series available), 2 series are destroyed (index 1 and 2) !
If I use Delete Bouton available on TeeChart Editor Control it is working fine (only 1 serie is destroyed)
I expect I do something wrong but I don't see where is my mistake...
Could you help me ?
Thks a lot
Guilz
Re: RemoveSeries Issue
Post by Yeray » Thu Aug 19, 2010 3:40 pm
Hi Guilz,
Yes, this is a known bug already in the defect list to be fixed asap (TA05014784)
Guilz
Post by Guilz » Thu Aug 19, 2010 3:51 pm
Thanks a lot for your response.
Guilz
Guilz
Post by Guilz » Fri Aug 20, 2010 6:55 am
Yeray,
Any idea about the date of the next ActiveX release ?
Guilz
Post by Yeray » Fri Aug 20, 2010 11:26 am
Hi Guilz,
I glad to announce that we've already fixed this problem (TA05014784).
I've sent the new ocx that includes the fix to the mail you have registered in this forums.
Guilz
Post by Guilz » Fri Aug 20, 2010 11:38 am
Thanks a lot Yeray - It is working properly.
As usual, the Steema support is excellent :wink:
Kind regards,
Guilz
Post by Yeray » Fri Aug 20, 2010 12:37 pm
Hi Guilz,
You're welcome! :D
TonyVSUK
Post by TonyVSUK » Mon Aug 23, 2010 9:25 am
Yeray wrote:Hi Guilz,
Can you send me the OCX as well please?
Post by Yeray » Mon Aug 23, 2010 3:36 pm
Hi Tony,
Just done!
Guilz
Re: RemoveSeries Issue with Bollinger
Post by Guilz » Fri Aug 27, 2010 6:53 am
In my previous post about Bollinger you suggest to set property ShowInEditor to True to display it in Editor.
Look at this new issue: when trying to delete the first serie of bollinger series, Teechart component crash
At this step we delete Bollinger Band2. Working fine
Now, we will try to delete Bollinger Band1:
It is crashing with VB6 environment and with .Net.
Could you fix this issue ? Crash is never welcomed :lol:
Thanks for your help :D
Kind regards,
Guilz
Post by Yeray » Fri Aug 27, 2010 2:19 pm
Hi Guilz,
Is the purpose of making visible the internal series to destroy it? If you don't want it to be shown you can simply set it Active = false.
However, you are right that having a source series and a bollinger function the IDE crashes if you try to remove the two last series, so I've added it to the defect list to be fixed in future releases (TA05015119):
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scFastLine
  TChart1.Series(0).Pen.Width = 2
  TChart1.Series(1).SetFunction tfBollinger
  TChart1.Series(1).DataSource = TChart1.Series(0)
  TChart1.RemoveSeries TChart1.SeriesCount - 1
Guilz
Post by Guilz » Fri Aug 27, 2010 2:39 pm
Yeray,
Using Active method on a serie does not destroy it...so it is more complicated to manage it by code because some series could be not active if user don't want to show them and some series are not active because they would like to destroy them ! Quite confusing...
If I look the last release date it was in 2010 of march...the release period is very long...Any idea for the next date ?
Guilz
Post by Yeray » Mon Aug 30, 2010 10:39 am
Hi Guliz,
We are working on the next ActtiveX version release that we hope can be published soon.
guilz2010
Post by guilz2010 » Mon Dec 13, 2010 1:12 pm
Hi Steema Support Team,
I'm a bit disappointed to view that this issue (TA05015119) is still not fixed in v8 version (only critical bugs are now fixed in v8 :evil: ).
BUT it is NOT normal that this bug is present in v2010 version too and haven't been solved since august (6 months).
Shame on you Steema Team :twisted:
Guilz
Post by Yeray » Wed Dec 15, 2010 1:38 pm
Hi Guilz,
As you'll understand, we try to give more priority to a bug/request as more critical we find it is, or more customers are affected/interested.
I've incremented the priority of TA05015119.
