Good day,
I am using a TColorGridSeries to generate a scrolling color plot. My X axis values are aximuth values from 0 to 360, and I display 100 angles at a time. Once the 1st hundred are displayed, I redraw the axis labels, shifting old values to the left and adding a new value to the end (right). Everything works fine until I have a zero crossing. I think the problem is when I call Chart1.Axes.Bottom.SetMinMax(min, max). Since max cannot be less then min. For example, my left most axis value may be 250 and the right most might be 0.
I have the following code set:
Chart1[0].VertAxis := aBothVertAxis;
Chart1[0].HorizAxis := aBothHorizAxis;
Chart1.Axes.Top.OtherSide := False;
Chart1.Axes.Right.OtherSide := False;
Chart1.Series[0].IrregularGrid := False
Now I can call AddXYZ with X and Z parameters set as integers then, set the axis labels like this:
Chart1.Axes.Top.SetMinMax(Min, Max);
Chart1.Axes.Bottom.Items.add(BlkCnt-1,Format('%-.2f',[PlotParam.AngleData[High(PlotParam.AngleData)]]));
This all works fine until the zero crossing occurs. Is there a way to just set the lables without having to call SetMinMax?
Scrolling Axes Labels
Re: Scrolling Axes Labels
Hi dpatch,
It would be helpful if you could arrange a simple example project we can run as-is to reproduce the situation here because right now I'm not sure about how are you exactly populating your series, how are you redrawing the labels, shifting the old values,...
Here is a simple example that shows what I am trying to do. I have sample data, but makes the upload too big. Is there an email address I can send it to?
Thanks in advance,
dave
Thanks in advance,
dave
Hi dave,
I have modified your project a little bit. I removed custom labels, used point labels and also set axes to be automatic. Doing so I now get labels all the time. However, this may not be what you are looking for. Could you please have a look at the example and let me know where you'd like to go from here? Or am I completely in the wrong way?
BTW: Files may also be posted at our upload page.
- Strip Example.zip
- (6.35 KiB) Downloaded 888 times
Narcis,
Thanks for your fast response!
I see what you did and it looks good. But, how come once the scrolling begins, the x axis labels go from showing many at the defined increment to only one on the far left?
Also, you made a call to Chart1[0].Clear instead of clearing the individual values. I have always thought that this call has a bug. When you call Chart1[0].Clear, it clears all the setup you have previously done...like setting the color palette. Is there another way to clear the plot display without loosing the plot setup?
Thanks again!
Thanks again!
Hi dpatch,
But you implemented this:
This means all series values are clearead at each loop! Changing code above for line below solves the problem .
Is that what you were looking for? I attach full project as well.
You're welcome!Thanks for your fast response!
I think I have found the problem. When scrolling begins, in the code, you wrote:I see what you did and it looks good. But, how come once the scrolling begins, the x axis labels go from showing many at the defined increment to only one on the far left?
//...Clear previous 100 columns values in the chart.
(Chart1.Series[0] as TColorGridSeries).XValues.Delete(0, (Chart1.Series[0] as TColorGridSeries).XValues.Count);
(Chart1.Series[0] as TColorGridSeries).YValues.Delete(0, (Chart1.Series[0] as TColorGridSeries).YValues.Count);
(Chart1.Series[0] as TColorGridSeries).ZValues.Delete(0, (Chart1.Series[0] as TColorGridSeries).ZValues.Count);
Chart1[0].Delete(0, fChartSteps);
Ok, I see. I don't think it's a bug but it clears all series ValueLists, colors included. I was trying to simplify the code, so this would also do the job:Also, you made a call to Chart1[0].Clear instead of clearing the individual values. I have always thought that this call has a bug. When you call Chart1[0].Clear, it clears all the setup you have previously done...like setting the color palette. Is there another way to clear the plot display without loosing the plot setup?
Chart1[0].Delete(0, Chart1[0].Count);
- Strip Example.zip
- (6.36 KiB) Downloaded 943 times
Narcis,
Now you know why I always kept your email address. It looks like this absoultely solved my problem.
Thank you very much!!!
dave
dave
Hi Dave,
Je je. You're very welcome!!
