TChart repaint failure
RichTat
Post by RichTat » Mon Jun 21, 2010 3:47 pm
TeeChart 2010 does not always repaint a chart after window is brought to the foreground.
Example to illustrate the problem in C++Builder 2010: create series values on form show event with Series1->Add() and add a button with code:
Chart1->TeeCreateBitmap(clRed,Chart1->ClientRect);
After clicking the button, the chart is no longer repainted when the form is brought to the foreground.
Similar effect in Delphi 2010.
This has come to light using TeeChart 2010 with Developer Express printing and preview controls.
is this a bug or am I missing something ?
Re: TChart repaint failure
Post by Narcís » Wed Jun 23, 2010 8:34 am
Hi RichTat,
I'm not sure how should I reproduce the issue. I implemented a form like this:
uses Series;
var i: Integer;
  Chart1.AddSeries(TLineSeries.Create(Self));
  for i:=0 to 10 do
    Chart1[0].Add(random);
  Chart1.TeeCreateBitmap(clRed, Chart1.ClientRect);
After I press the button I move other windows above the application and then bring the application to the foreground. Is this what I am supposed to do? Should I change the implementation or perform any other step?
Post by Narcís » Wed Jun 23, 2010 8:50 am
Hi RichTat,
As an update, I could reproduce a very similar issue which is being discussed here. Is this the same problem at your end?
RichTat
Post by RichTat » Wed Jun 23, 2010 3:07 pm
Hello Narcis
Proceed as follows with C++ Builder 2010 and TeeChart 2010:
Step 1: Create a form
Step 2: Add a TChart component Chart1 (no editing necessary)
Step 3: Add a button
Step 4: Add button click code to produce the following code module:
#include <vcl.h>
#pragma hdrstop
#include "Unit04.h"
#pragma package(smart_init)
#pragma link "Series"
#pragma link "TeEngine"
#pragma link "Chart"
#pragma link "TeeProcs"
#pragma resource "*.dfm"
TForm1 *Form1;
__fastcall TForm1::TForm1(TComponent* Owner)
	: TForm(Owner)
void __fastcall TForm1::Button1Click(TObject *Sender)
	Chart1->TeeCreateBitmap(clBlack,Chart1->ClientRect );
Step 5: Compile and run the program
Step 6: Click the button
Step 7: Bring another window to the foreground maximum screen size to cover the form
Step 8: Bring the form back to the foreground and the chart is not repainted.
RichTat
Post by Narcís » Fri Jun 25, 2010 12:02 pm
Hi RichTat,
I'm not able to reproduce this. Now I can't reproduce TV52014993 consistently either. Does this occur consistently at your end? I guess it's the same issue as copying to clipboard calls TeeCreateBitmap method. Anyway, we will investigate TV52014993 further.
RichTat
Post by RichTat » Mon Jun 28, 2010 2:22 pm
Hi Narcis
I have tried my program executable on 2 XP and one Vista PC all with the predicted result of non-painting.
I build the project without runtime packages.
You can download my C++ Builder 2010 test project at
http://reetec.co.uk/files/useful/steema99.zip
This includes the project files (based on my development path) and executable.
regards RichTat
Post by Narcís » Thu Jul 01, 2010 11:54 am
Hi RichTat,
Thanks for the example project. We could reproduce the problem here both in Windows 7 and Windows XP machines. However, I'm not able to reproduce it on my Windows 7 machine :shock:. We are investigating what makes the difference. We will get back to you one we have further news.
Post by Yeray » Fri Jul 02, 2010 2:52 pm
Hi RichTat,
We've seen that on Windows 7, if you activate "Use visual styles on windows and buttons", the problem isn't reproducible:
But this option doesn't seem to have the same effect regarding this issue neither on Windows Vista or XP.
We've also seen that forcing a repaint after calling TeeCreateBitmap with Chart1.Draw, the problem disappears.
Could you please confirm this?
RichTat
Post by RichTat » Mon Jul 05, 2010 1:08 pm
Hello Yeray
1) Setting the WINDOWS visual effects option has no effect on our XP development computer
2) Executing the Chart1->Draw() function IMMEDIATELY after the Chart1->TeeCreateBitmap() function in the same procedure eliminates the problem.
3) Executing the Chart1->Draw() function as a separate, later, operation using a separate button redraws the chart but does not remove the problem.
RichTat
Post by Narcís » Wed Jul 07, 2010 1:42 pm
Hi RichTat,
Thanks for your feedback. We are working on fixing the issue for the next maintenance release.
Post by Yeray » Thu Jul 08, 2010 7:03 am
Hi RichTat,
We have fixed the problem TV52014993 so it will be available in the next maintenance release.
