Selection of series' points
Chris.CHWU
Post by Chris.CHWU » Tue Jun 09, 2009 9:11 am
Greetings,
I want to select certain points of a sereis by draging a rectangle region.
I tried MouseDown and MouseUp events but just got the x-coordinates and y-coordinates in pixels (not relative to the values of x-axis and y-axis).
Do you have any suggestion about my requirement?
Post by Yeray » Tue Jun 09, 2009 10:52 am
Hi Chris,
Here there is a topic where something similar was discussed.
Chris.CHWU
Re: Selection of series' points
Post by Chris.CHWU » Wed Jun 24, 2009 2:36 am
Greetings,
I want to highlight selected points after selection.
The way coming to my mind is to new a series of the selected points.
Then I could set the pointer style, color... any way I want to present the highlight.
But it seems not a good solution. Do you have any suggestion?
Post by Yeray » Thu Jun 25, 2009 1:25 pm
Hi Chris,
Here you have an example using the same series, simply changing the color of the selected points:
uses TeCanvas;
var Selected: array of bool;
    DrawRectangle: bool;
    StartX, StartY: Integer;
  Chart1.View3D := false;
  Chart1.AllowZoom := false;
  DrawRectangle := false;
  Chart1[0].FillSampleValues(25);
  SetLength(Selected, Chart1[0].Count);
  DrawRectangle := true;
  StartX := X;
  StartY := Y;
  Y: Integer);
  if DrawRectangle then
    Chart1.Repaint;
    Chart1.Canvas.Brush.Style := bsClear;
    Chart1.Canvas.Rectangle(StartX, StartY, X, Y);
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
var i: Integer;
  for i:=0 to length(Selected)-1 do
    if PointInRect(Rect(StartX, StartY, X, Y), Chart1[0].CalcXPos(i), Chart1[0].CalcYPos(i)) then
      Selected[i] := true
      Selected[i] := false;
  Chart1.Repaint;
function TForm1.Series1GetPointerStyle(Sender: TChartSeries;
  ValueIndex: Integer): TSeriesPointerStyle;
  Result := psRectangle;
  if Selected[ValueIndex] then
    Sender.ValueColor[ValueIndex] := clRed
    Sender.ValueColor[ValueIndex] := Sender.Color;
Chris.CHWU
Post by Chris.CHWU » Fri Jun 26, 2009 2:12 am
Execuse me. Does this work in VB .NET version?
I try to implement it but encounter two problems:
1. The series.ValueColor[index] is a Read-Only property.
2. GetPointerStyle event is not found.
Post by Sandra » Fri Jun 26, 2009 9:32 am
Hello Cris,
You can do a similar code with next example, please check that this code works fine in your application:
Private Sub p_GetPointerStyle(ByVal series As Steema.TeeChart.Styles.CustomPoint, ByVal e As Steema.TeeChart.Styles.GetPointerStyleEventArgs)
        series(e.ValueIndex).Color = Color.Orange
If you want to created even in VB you coud do so two ways:
First
: if you would to directly in run time(code), you needs to do next:
AddHandler p.GetPointerStyle, AddressOf Me.p_GetPointerStyle
Second: if you would to design time, you have selected event
I hope will helps you,
Chris.CHWU
Post by Chris.CHWU » Mon Jun 29, 2009 2:20 am
[quote="Sandra"]Hello Cris,
Greetings,
Thanks. It worked in my program. But my series is of the type Steema.TeeChart.Styles.Line.
This way would change not only the pointer's color but also the line associated with the pointer.
Is there any way to avoid this? I just want the pointer's style changed.
Thanks for you help.
Post by Sandra » Mon Jun 29, 2009 8:10 am
Hello Cris,
Please check next code, that change only pointer's style, for example orange color.
Initialize: Add this two lines
line.Pointer.Visible = true
AddHandler line.GetPointerStyle, AddressOf Me.line_GetPointerStyle
Line_GetPointerStyle Event:
 Private Sub line_GetPointerStyle(ByVal series As Steema.TeeChart.Styles.CustomPoint, ByVal e As Steema.TeeChart.Styles.GetPointerStyleEventArgs)
        e.Color = Color.Orange
I hope that will helps
Chris.CHWU
Post by Chris.CHWU » Tue Jul 07, 2009 7:06 am
Greetings,
I enabled the zooming tool after highlighting but met some problems.
The line associated with the highlighted points would be drawed outside the chart region.
Before zooming:
before zooming
After zooming:
after zooming
Do you have any iedas about this?
Post by Sandra » Tue Jul 07, 2009 10:17 am
Hello Cris,
I have commented two things:
First:
Is possible that you have property tChart1.Aspect.ClipPoint= false, change this for true. I check with last version and works fine.
Second: If previous not works, please you could say what is your actualy version of TeeChartFor .Net?
If your version isn't laster, please update the version and tester code.If the problem still appears you can send a simple example because we can reproduce here. Now,you can attach your projecte direcly in the forums post.
Chris.CHWU
Post by Chris.CHWU » Thu Jul 16, 2009 3:11 pm
Sandra wrote:Hello Cris,
Coule I draw a circle on the outside of the pointer?
Please see the below image.
Post by Sandra » Fri Jul 17, 2009 12:56 pm
Hello Chris,
I find two solutions for draw a circle, in your selection. The first solution is more simple than the second, but both make a circle around the pointer.
Firts solution:
Using GetPointStyles
bool[] Selected;
        Steema.TeeChart.Styles.Line line;
        bool drawrectangle;
        Rectangle rect;
            line = new Steema.TeeChart.Styles.Line (tChart1.Chart);
            line.FillSampleValues();
            line.Pointer.Visible = true;
            tChart1.Aspect.ClipPoints = true;
            drawrectangle = false;
            Selected = new bool[line.Count];
            tChart1.Panning.MouseButton = MouseButtons.Middle;
            tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
            tChart1.MouseUp += new MouseEventHandler(tChart1_MouseUp);
            tChart1.MouseDown += new MouseEventHandler(tChart1_MouseDown);
            tChart1.AfterDraw += new Steema.TeeChart.PaintChartEventHandler(tChart1_AfterDraw);
           line.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(line_GetPointerStyle);
            tChart1.Draw();
            ResetCoords();
        void tChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            if ((X0 != -1) && (Y0 != -1))
                if (drawrectangle)
                    g.Brush.Visible = false;
                    g.Pen.Color = Color.Black;
                    g.Rectangle(X0, Y0, X1, Y1);
 void tChart1_MouseDown(object sender, MouseEventArgs e)
            if (e.Button == MouseButtons.Right)
                drawrectangle = true;
                X0 = e.X;
                Y0 = e.Y;
        void tChart1_MouseUp(object sender, MouseEventArgs e)
                rect = new Rectangle(X0, Y0, e.X -X0, e.Y-Y0);
                for (int i = 0; i < Selected.Length; i++)
                    Point p = new Point(tChart1[0].CalcXPos(i), tChart1[0].CalcYPos(i));
                    if (rect.Contains(p))
                        Selected[i] = true;
                        Selected[i] = false;
               ResetCoords();
            tChart1.Draw();
        private int X0, Y0, X1, Y1;
        void tChart1_MouseMove(object sender, MouseEventArgs e)
                        X1 = e.X;
                        Y1 = e.Y;
                tChart1.Invalidate();
        void line_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            e.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
            if (Selected[e.ValueIndex])
                series.Pointer.Pen.Color = Color.Red;
                series.Pointer.Pen.Width = 2;
                series.Pointer.Pen.Color = series.Color;
                series.Pointer.Pen.Width = 1;
        private void ResetCoords()
            X0= -1;
            Y0= -1;
Second solution: Using AfterDraw and drawing directly in canvas.
    bool[] Selected;
        bool drawrectangle;
        Rectangle rect;
            line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            tChart1.Draw();
            ResetCoords();
                if (drawrectangle)
                Rectangle rect1 = new Rectangle(p.X - line.Pointer.HorizSize - 5, p.Y - line.Pointer.VertSize - 5, (line.Pointer.HorizSize + 5) * 2, (line.Pointer.VertSize + 5) * 2);
                if (Selected[i])
                    g.Pen.Color = Color.Blue;
                    g.Ellipse(rect1);
                X0 = e.X;
                Y0 = e.Y;
                        Selected[i] = true;
               ResetCoords();
            tChart1.Draw();
                        X1 = e.X;
                        Y1 = e.Y;
                e.Color = Color.Red;
            X0= -1;
            Y0= -1;
Please, check that previous codes works correctly in your application.
I hope will helps.
wwp3321
Post by wwp3321 » Wed Mar 17, 2010 8:53 am
Thanks!
