I'm using candlestick series for a financial application, I now need to add a number of pivot points to the chart, which are basically horizontal lines.
What series should I use as the y axis for each pivot point, support and resistance is constant and the x axis is a time series as per the candlestick series.
any example code would benefit.
thanks
candlesticks and pivot points
- Site Admin
- Contact:
Hi laurence,
In that case I recommend you to use ColorLine tools associated to the left axis. You'll find ColorLine tool examples at All Features\Welcome!\Tools\Color Line in the features demo, available at TeeChart's program group.
- Site Admin
- Contact:
Hi laurence,
You're welcome. I'm glad to hear that helped.
I don't think it is a bug. Have you tried setting NoLimitDrag to false?by the way there is a bug in the TcolorLine, when a line is drawn just outside the axis it shows in the panel area.
TChart1.Tools.Items(0).asColorLine.NoLimitDrag = False
