I need to set the Font for the header but can't find a SetFont Property for CTitles. I have the following
e.g.
LOGFONT mlf;
mChart->GetHeader().SetFont(mLf)
does not work (there is no SetFont method for CTitles)
Can someone point me in the right direction?
Setting Font for TChart Header
- Site Admin
- Contact:
Thanks. SetName() worked for me. Now I want to set the size of the font using the size I get from a CFontDialog but the text on the Chart is very big. I'm using
CFontDialog dlg;
dlg.doModal();
m_Chart->GetHeader().GetFont().SetSize( dlg.GetSize());
I also tried setting the height using the size as follows:
long newSize = m_Chart->GetHeader().GetFont().GetSize() * m_Chart->GetHeader.GetFont().GetPixelsPerInch/72;
m_Chart->GetHeader().GetFont().SetHeight(newSize);
This also produced much larger text than expected...
What property should I be setting?
CFontDialog dlg;
dlg.doModal();
Hi nbp,
Here is an example of how you could set the chart's header font size to be shown at the editor:
LOGFONT lf;
memset(&lf, 0, sizeof(LOGFONT));
CClientDC dc(this);
lf.lfHeight = -MulDiv(m_Chart1.GetHeader().GetFont().GetSize(), dc.GetDeviceCaps(LOGPIXELSY), 72);
CFontDialog fdlg(&lf);
fdlg.DoModal();
