Labels in Gantt chart disappear in new build
Exact Software
Post by Exact Software » Thu Feb 12, 2004 3:42 pm
Since i am using the last build (1.1.1499.42325) i have a problem with my gantt charts.
Some of the labels (Y-Axis) don't appear on the chart anymore. When i am stepping through my code i see that the Add method is called correctly.
Public Function Add(ByVal start As Date, ByVal endDate As Date, ByVal y As Double, ByVal text As String) As Integer
The Gantt shapes are drawn correctly in the grid, it's just the labels.
Does anybody encountered the same problems or did you guys @ steema know of this problem ?
Thanks in advance 4 your answers !
Post by Pep » Fri Feb 13, 2004 10:10 am
could you please post the code you're using in the steema.public.attachments newsgroup so we can reproduce the problem "as is" here ?
Exact Software
Post by Exact Software » Fri Feb 13, 2004 2:40 pm
Dear Pep,
Thanks for your answer. Unfortunately i cannot send you the complete code, it is built on top of our own DLL's.
I can give you some snippets though: this is basically how my code works.
In an aspx page I declare a webchart, and add a gantt series
Dim wchart  As Web.WebChart = New Web.WebChart
Dim chart As Chart = wchart.chart
Dim Planned As Styles.Gantt = chart.Series.Add(New Styles.Gantt())
Planned.Title = "Planned"
Planned.XValues.DateTime = True
Then i add data to the series, looping through a query result.
Dim v(,) As Object = Query()
For i As Integer = 0 To Ubound(v)
	Planned.Add(v(i, 0), v(i, 1), i, v(i, 2))
Next
Then i export the chart to a PNG, store it in the session and parse it on my page. (parsing not in code sample)
Dim ms As new MemoryStream
chart.Export.Image.PNG.Save(ms)
Session(chartid) = ms
I verified that every time i call the Planned.Add i pass correct values. This worked perfectly OK in the version for the 1.0 framework but in the latest build the labels disappear.
Exact Software
Post by Exact Software » Tue Feb 24, 2004 9:07 am
Can anybody please look into this problem, or tell me what more information you need ?
This is critical functionality !
Post by Marc » Tue Feb 24, 2004 11:56 am
Thanks for the bug report, the change that slipped in to break this functionality in the latest build will be corrected. Apologies for the inconvenience.
As a workaround you can set the following before populating the Series:
Planned.XValues.Order = Steema.TeeChart.Styles.ValueListOrder.None
Post by Marc » Tue Feb 24, 2004 12:20 pm
Small correction:
better (for consistency)
Planned.StartValues.Order = Steema.TeeChart.Styles.ValueListOrder.None
than
Exact Software
Post by Exact Software » Tue Feb 24, 2004 12:28 pm
Thanks a lot marc ! Your workaround does the job and my gantt chart looks nice again.
Do you have any idea when this bug will be solved ?
Post by Pep » Tue Feb 24, 2004 1:09 pm
Build 1.1.1499.42325 was released on 9/Feb/2004, meaning that the next maintenance release should be available in May/June.
