TeeChart NET for Blazor Legend checkboxs not working
dynamicrisk
Post by dynamicrisk » Wed Aug 14, 2024 3:19 pm
I am trying to add checkboxes to my chart legend using Legend.ActiveStyle = LegendActiveStyles.CheckBox and Legend.CheckBoxes = true. Neither seem to be working.
Here is the sample code I am using:
public Task<string> GetJSChart(int chartType, int width, int height)
Steema.TeeChart.TChart mChart = new TChart();
bool animate = false;
switch (chartType) {
case 0: Line line = new Line(mChart.Chart);
animate=true;
break;
case 1:
Points points = new Points(mChart.Chart);
Points facilities = new Points(mChart.Chart);
animate=true;
break;
case 2: Area area1 = new Area(mChart.Chart);
Area area2 = new Area(mChart.Chart);
animate = true;
break;
case 3: break;
case 5: Bubble bubble = new Bubble(mChart.Chart); animate = true; break;
case 6: Candle candle = new Candle(mChart.Chart); break;
case 7: Gantt gantt = new Gantt(mChart.Chart);
break;
case 31: Pie pie = new Pie(mChart.Chart); break;
case 32: Donut donut = new Donut(mChart.Chart); break;
case 33:
case 34: CircularGauge cGauge = new CircularGauge(mChart.Chart); break;
var series = mChart.Series[0];
var seriesFacility = mChart.Series[1];
mChart.Header.Text = "ILI Chart";
mChart.Axes.Left.Title.Text = "Clock";
mChart.Axes.Left.Inverted = true;
mChart.Axes.Bottom.Title.Text = "Odometer";
mChart.Legend.ActiveStyle = LegendActiveStyles.CheckBox;
mChart.Legend.CheckBoxes = true;
mChart.Legend.LegendStyle = LegendStyles.Series;
int counter = 0;
foreach (Series s in mChart.Series)
if (series.GetType() == typeof(Bubble))
((Bubble)(s)).Pointer.Gradient.Visible = true;
((Bubble)(s)).Pointer.Pen.Visible = false;
s.FillSampleValues(50);
else if ((series.GetType() == typeof(Gantt)))
s.FillSampleValues(9);
// scatter series
if(counter == 0)
s.FillSampleValues();
for (int i = 0; i < 101; i++)
Random rnd = new Random();
s.XValues.Value = rnd.NextDouble() * 1000;
s.YValues.Value = rnd.NextDouble() * 12;
// Facilities
if (counter == 1)
s.FillSampleValues(15);
for (int i = 0; i <= 14; i++)
s.YValues.Value = 0;
((Points)(s)).Pointer.Style = PointerStyles.DownTriangle;
((Points)(s)).Pointer.VertSize = 12;
((Points)(s)).Pointer.HorizSize = 12;
counter++;
// ToDo
ChartAggregate aggregate = ChartAggregate.Average;
//mChart.Chart.Series.Aggregate
if ((series.GetType() != typeof(Gantt)))
mChart.Axes.Left.SetMinMax(0, 12);
chartName = "dynoTeeChart";
mChart.Export.Image.JScript.ChartName = chartName;
MemoryStream ms = new MemoryStream();
mChart.Export.Image.JScript.Width = width;
mChart.Export.Image.JScript.Height = height;
mChart.Export.Image.JScript.DoFullPage = false; //inline, no page <html> header tags
if ((series.GetType() == typeof(Pie)) ||
(series.GetType() == typeof(Donut)))
series.Marks.Visible = true;
series.Marks.Arrow.Visible = false;
series.Marks.Arrow.Color = Color.White;
series.Marks.Transparent = true;
series.Marks.Pen.Transparency = 100;
series.Marks.Pen.Color = Color.White;
series.Marks.Font.Color = Color.White;
mChart.Export.Image.JScript.CustomCode = getCustomCodeOp2(mChart);
mChart.Export.Image.JScript.CustomCode = getCustomCode1(animate, mChart, series);
((Gantt)series).Brush.Gradient.Visible = false;
((Gantt)series).NextTasks[0] = 6;
mChart.Axes.Left.Title.Text = "task";
if ((series.GetType() == typeof(CircularGauge)))
mChart.Axes.Left.Title.Text = "µHz";
var customCode = new List<string>();
if (chartType == 34)
customCode.Add("modGauge(" + chartName + ", " + chartName + ".series.items[0]" + ");");
customCode.Add("setTimeout(modVal, 500);");
((CircularGauge)(mChart[0])).Value = 0;
customCode.Add(chartName + ".series.items[0]" + ".format.shadow.visible=false;");
customCode.Add(chartName + ".series.items[0]" + ".back.visible=false;");
customCode.Add("growVal(" + chartName + ");");
customCode.Add("setTimeout(growVal, 500);");
mChart.Export.Image.JScript.CustomCode = customCode.ToArray();
title = mChart.Series[0].Description;
mChart.Export.Image.JScript.Save(ms);
ms.Position = 0;
StreamReader reader = new StreamReader(ms);
//setup our chart name, here 'dynoChartName'.
string result = "<script> var " + chartName + "; " + reader.ReadToEnd() + "</script>";
return Task.FromResult(result);
Re: TeeChart NET for Blazor Legend checkboxs not working
Post by Marc » Fri Aug 16, 2024 11:42 am
The TeeChart Javascript library doesn't yet support Legend CheckBox. I've added it as a feature-request.
Click sensoitivity for the Legend could be added in different ways. We'll make up a code example.
dynamicrisk
Post by dynamicrisk » Thu Aug 22, 2024 1:58 pm
Just following up to see if there are any updates on this.
Edu
Post by Edu » Fri Aug 23, 2024 10:13 am
The team has been making progress, and we're getting close to finalizing a new update that includes this functionality. We expect it to be ready soon.
I'll share more details as soon as they're available.
Thank you for your patience.
Best regards,
Edu
Edu
Edu
Post by Edu » Mon Sep 02, 2024 10:13 am
I’m pleased to inform you that your request has been successfully completed and is now ready for implementation. With the latest release (2024.8.30), you can begin using it immediately.
tChart.Legend.ActiveStyle = LegendActiveStyles.CheckBox;
And this is how it looks like:
Best regards,
Edu
Edu
