Various Compile Issues with TeeChart VCL 2024.40
Mark Mayes
Post by Mark Mayes » Tue Jul 02, 2024 4:47 pm
I am running into issues with TeeChart VCL 2024.40 Pro with Source Code. First, when compiling a basic project in the IDE consisting of a TForm and a chart, I get the following message:
F2051 Unit VCLTee.Chart was compiled with a different version of System.RTLVersion121
So I tried to use TeeRecompile to fix the issue. However, TeeRecompile received an internal error. Here is the log:
TeeChart Pro
Compilation started: 6/6/2024 10:59:38 AM
Win32 v29
Tee929
Embarcadero Delphi for Win32 compiler version 36.0
Copyright (c) 1983,2023 Embarcadero Technologies, Inc.
88533 lines, 0.89 seconds, 992204 bytes code, 4836 bytes data.
TeeUI929
Cannot recompile Delphi package: TeeUI929.dpk
VCLTee.EditChar.pas(13) Fatal: F2084 Internal Error: URW7830
EXCEPTION:
Compilation aborted.
The result was the the design package was removed from the IDE. I’ve reinstalled the package.
Here are my particulars.
I’m using RAD Studio 12 patch 1. (Enterprise Edition, Version 29.0.50491.5718)
I’m using Windows 11 Pro
TeeRecompile.exe is from April 1, 2024, 7:55 A.M.
- Mark Mayes
Re: Various Compile Issues with TeeChart VCL 2024.40
Post by Yeray » Wed Jul 03, 2024 7:05 am
I haven't heard about this one.
It sounds as if the VCLTee.Chart.dcu unit found in the library path was build before installing some update or patch in the IDE.
I'd try to rebuild the sources, as you did.
TeeUI929
EXCEPTION:
I find the F2084 error may be due to a memory consumption limit (here).
Make sure you don't have big programs open and try to run TeeRecompile again to see if it makes any difference?
BTW, how many memory has your machine?
Mark Mayes
Post by Mark Mayes » Fri Jul 05, 2024 3:51 pm
I have 32GB of memory, of which 41% is free. I was running several Microsoft programs (e.g., Teams, Edge), so I shut them down. I received the exact same error at the same place. Also, task manager showed that memory usage did not change significantly while TeeRecompile was running. And I was running as administrator.
Mark Mayes
Post by Mark Mayes » Mon Jul 08, 2024 1:26 pm
Sorry, that was 41% used, not free.
Post by Yeray » Mon Jul 08, 2024 1:28 pm
I've just double checked it and it seems the IDE version I use here (29.0.51961.7529) is different from yours (29.0.50491.5718).
I'm not sure it will make any difference, but maybe there's an update you can apply.
Mark Mayes
Post by Mark Mayes » Wed Jul 10, 2024 3:47 pm
I'll see if I can get an answer from Embarcadero. I've actually asked 3 times about an update, but haven't heard anything back. I've been waiting since late June. It's really strange behavior from them. They offered a demo. I explained that I've been using Delphi since version 2 and don't need a demo. I just need to know any upgrade path available.
Mark Mayes
Post by Mark Mayes » Fri Oct 04, 2024 8:06 pm
It works fine with Delphi 12.1. The only problem I have now is that is shows Trial version. There is no way to enter the registration information because the installer picks up on the fact that it's registered.
Post by Yeray » Fri Oct 04, 2024 8:44 pm
Do you mean the about box says "unregistered"?
The installer attempts to write the license information to the registry only to display this information in the about box.
This seems to fail in some circumstances, but it doesn't affect anything else.
Or the about box is automatically opened every time a chart is created?
In that case, I'd suggest you to fully uninstall TeeChart and reinstall it again.
