Marks Placement when using mouse wheel
Errol
Post by Errol » Mon Aug 20, 2018 6:17 am
Good evening
I use stacked bar charts to represent a geological column. Besides each section (strata) I place a comment using the code below:
procedure TPBQuickGraph.PlaceComments;
var
  s, i, tmpSize, LIndex, LMarksHeight : integer;
  LComment: string;
  Chart.Draw;
  LIndex := 0; // legend included so need to pick 2, 4, etc (0 = legend)
  for s := 1 to fIntervalQueryCollection.SeriesListB.Count - 1 do
    if (s mod 2 = LIndex) then // every second series in SeriesListB
      with TUnitBarSeries(fIntervalQueryCollection.SeriesListB.Objects[s]) do
        fIntervalQueryCollection.IntervalQuery.First;
        for i := 0 to TUnitBarSeries(fIntervalQueryCollection.SeriesListB.Objects[s]).Count - 1 do
          LComment := fIntervalQueryCollection.IntervalQuery.FieldByName('Strata Comment').AsString;
          with Marks.Positions[i] do
            if (Labels[i] <> '') then
              Custom := true;
              LeftTop.X := CalcXPos(0) + fBarWidth + fCommentStart;
              tmpSize := CalcYSizeValue(YValue[i]);
              LMarksHeight := Marks.Height;
              LeftTop.Y := CalcYPos(i) - (tmpSize div 2) - (LMarksHeight div 2);
            end
              Marks.Item[i].Text.Text := '';
          fIntervalQueryCollection.IntervalQuery.Next;
This places the comments correctly when first displaying the graph and when called after the OnZoom, OnUndoZoom and OnScroll events. However, calling PlaceComments in the OnMouseWheel event misplaces the marks up or down as shown in the following figures.
The attachment Comment_Location.png is no longer available
The attachment Comment_Location_Down.png is no longer available
Correct position of comments
I would be grateful if you can suggest how I might fix this.
Best regards
Errol
Re: Marks Placement when using mouse wheel
Post by Yeray » Wed Aug 22, 2018 6:37 am
Maybe you need to force another repaint (Chart1.Draw) at the end of this method.
I can't see all the images, could you please edit your opening post or reply adding them?
Errol
Post by Errol » Thu Aug 23, 2018 4:43 am
Good afternoon
Thanks for your suggestions. I have tried calling Chart.Draw at various places - in PlaceComments and in OnMouseWheel, to no avail.
I have attached the images again. I hope they get through this time.
The attachment Comment_Correct_Location.png is no longer available
The attachment Comment_Location_MouseWheelDown.png is no longer available
Correct comment location
Errol
Post by Errol » Thu Aug 23, 2018 4:46 am
I seem unable to attach the three images so I have attached images 2 and 3 here.
Comment location after mouse wheel down
Errol
Post by Errol » Thu Aug 23, 2018 4:48 am
And here is the final image. Each time, Preview shows the three images correctly, but when I submit the post, the attachments vanish
Comment location after mouse wheel up
Post by Yeray » Thu Aug 23, 2018 8:46 am
Hello Errol,
I'm sorry for the problems attaching images. There seems to be a bug in phpbb 3.2.2 (reference here). I've applied the fix and it seems to be working now.
Regarding the problem with the marks, note the OnMouseWheel event is fired before applying the axis scroll. That's why your PlaceComments method doesn't calculate the positions properly. You can set a flag at OnMouseWheel and call PlaceComments at OnAfterDraw event when that flag is set. Here a simple example:
testMarks.zip
(83.23 KiB) Downloaded 701 times
Errol
Post by Errol » Fri Aug 31, 2018 2:12 pm
Good evening
Thank you for your assistance here. I have implemented your suggestions and it works fine now. Obvious really, once one knows how to do it, but I find the TeeChart events a bit daunting at times.
Best regards
Errol
