SerieRegion with pattern - PDF export
athely
Post by athely » Mon Dec 18, 2017 1:40 pm
I have some problems when i want to print (in pdf throught PDFCreator in attachement) a chart with a serie region using a pattern.
1- Pattern seems to be zoomed and streched when canvas size is changed before print. The rendering is really not acceptable
2- Contrary to old version (Delphi 9 & Teechat v8.08), filled area seems to be a picture and not vectorial. Besides, pdf file size is very larger!
I use Delphi XE10.1 and TeeChart Pro VCL FMX Source Code 2017.20.
Thanks for your help
Anthony
Re: SerieRegion with pattern - PDF export
Post by Yeray » Mon Dec 18, 2017 3:00 pm
This is what I'm getting with a new simple example using RAD 10.2 Tokyo, TeeChart v2017.22 and PdfCreator 2.5:
Chart1.zip
(14.39 KiB) Downloaded 1721 times
If you still find problems with it, please try to arrange a simple example project we can run as-is to reproduce the problem here.
athely
Post by athely » Mon Dec 18, 2017 3:33 pm
I'm sorry, i forgot attachement in previous post...
Please find attached small project with serie region using pattern.
Pattern plotting is very important for me because it is representing geology.
TestTChartSerieRegionPattern - XE10.1.zip
(118.54 KiB) Downloaded 1519 times
Post by Yeray » Tue Dec 19, 2017 8:49 am
Here it is a screenshot comparing the chart and the pdf your project generates for me with v2017.22:
I'm trying to compare the result with TeeChart v8 but I'm getting an "29100 - Internal GhostScript Error" with GDI and I get a blank pattern in GDIPlus.
athely
Post by athely » Tue Dec 19, 2017 9:57 am
"29100 - Internal GhostScript Error" from PDFCreator is one of some reasons i decided to update my RAD & Teechart version.
Effectivelly, I'm getting this error with certain pattern and not with other.
Please find attached, small project (D9 & Teechat v8.08) using working pattern:
As you can see, quality of pdf export is very well!
TestTChartSerieRegionPattern - D9.zip
(51.03 KiB) Downloaded 1557 times
athely
Post by athely » Thu Dec 21, 2017 1:09 pm
Below same example as previous with Delphi XE10.1 & TeeChart 2017.10:
Pattern seems to be streched!
Any idea or workarround?
Anthony
Post by Marc » Thu Dec 28, 2017 9:34 am
Hello Anthony,
Any image pattern is likely to be stretched for a different output width/height ratio to the original Chart. I tried with a smaller image as brush pattern and note that it tiles so that may be a workaround. An alternative would be to use hatchstyle.
athely
Post by athely » Mon Feb 05, 2018 4:36 pm
Hi Marc!
HashStyle is not a good alternative for me, because user can choose its own geological pattern which is a bitmap.
To avoid stretch problem, i resize chart canvas to have exactly the same output width/height ratio (as you could have seen in my example). That's why I don't understand where the problem comes from! Besides, in previous TeeChart version, it works fine...
I really need to have this print feature working and so need your help.
Anthony
Post by Yeray » Wed Feb 07, 2018 9:37 am
Hello Anthony,
I've restored the technique that was used in AssignBrush in previous versions. Could you please tell us if this test version gives you the expected result?
TestTChartSerieRegionPattern.zip
(862.64 KiB) Downloaded 1575 times
athely
Post by athely » Thu Feb 08, 2018 8:13 am
This is exactly what i want!
How can I restore "the technique that was used in AssignBrush in previous versions" in my side?
Thanks a lot for your help!!!
Anthony
Post by Yeray » Thu Feb 08, 2018 10:45 am
Hello Anthony,
Since you have the sources, you can just open TeCanvas.pas, backup it, replace the TTeeCanvas.AssignBrush that matches the signature of the method below, and recompile.
Procedure TTeeCanvas.AssignBrush(const ABrush:TTeeBrush; AColor,ABackColor:TColor);
  procedure SetBrushBitmap(ABitmap:{$IFDEF LCL}TCustomBitmap{$ELSE}TBitmap{$ENDIF});
    Brush.Bitmap{$IFDEF FMX}.Bitmap{$ENDIF}:=ABitmap;
    {$IFNDEF FMX}
    {$IFDEF TEEWINDOWS}
    SetTextColor(Handle,ColorToRGB(AColor));
    {$ENDIF}
    {$ENDIF}
    BackMode:=cbmOpaque;
    BackColor:=ABackColor;
var tmp: TBitmap;
  FBrush.OnChange:=nil;
  if Assigned(ABrush.FImage) and Assigned(ABrush.FImage.Graphic)
     {$IFDEF FMX}and (not ABrush.FImage.Graphic.IsEmpty) {$ENDIF} then
    Brush.Style:=bsClear;
    if not (ABrush.FImage.Graphic is TBitmap) then
      {$IFDEF FMX}
      tmp:=TBitmap.Create(ABrush.FImage.Width, ABrush.FImage.Height);
      tmp.Canvas.DrawBitmap(ABrush.FImage, TRectF.Create(0,0,tmp.Width,tmp.Height),
        TRectF.Create(0,0,tmp.Width, tmp.Height),
        1);
      {$ELSE}
      tmp:=TBitmap.Create;
      TeeSetBitmapSize(tmp,ABrush.FImage.Width,ABrush.FImage.Height);
      tmp.Canvas.Draw(0,0,ABrush.FImage.Graphic);
      {$ENDIF}
      ABrush.FImage.Bitmap:=tmp;
      tmp.Free;
    SetBrushBitmap(ABrush.FImage.Bitmap);
  end
  if Assigned(ABrush.Bitmap)
     {$IFDEF FMX}and Assigned(ABrush.Bitmap.Bitmap) and (not ABrush.Bitmap.Bitmap.IsEmpty){$ENDIF}
     {$IFDEF CLX}and (not ABrush.Bitmap.Empty){$ENDIF}
     then
    SetBrushBitmap(ABrush.Bitmap{$IFDEF FMX}.Bitmap{$ENDIF});
  end
    {$IFDEF FMX}
    Brush.Assign(ABrush);
    {$ELSE}
    Brush.Bitmap:=nil;
    {$ENDIF}
    if Monochrome then
       AColor:=clWhite;
    FBrush.BackColor:=ABackColor;
    FCanvas.Brush.Assign(ABrush); // <-- redundant for GDI+ etc
  if Assigned(ABrush.FGradient) then
     Gradient.Assign(ABrush.Gradient)
     Gradient.Visible:=False;
  FBrush.OnChange:=ChangedBrush;
  DoChangedBrush(FBrush);
athely
Post by athely » Mon Feb 12, 2018 4:28 pm
Thank you a lot for your workarround, it is working very well!!!
Is it planned to fix this issue in futur release?
Again, thank you for your excellent support!
Anthony
