Pie Chart Size Adjustment?
PastorMic
Post by PastorMic » Tue Aug 29, 2017 1:01 pm
Been using TDBChart successfully in VCL, and wanted to build the same form in my FMX app. Created the dialogs and charts to be roughly the same size, however, the FMX version of the chart is very small in comparison to the same chart rendered in the VCL version. It's pretty much unusable in its current form.
What is the proper way to make the actual chart itself larger so that it's easier to read?
Mic
PastorMic
Re: Pie Chart Size Adjustment?
Post by PastorMic » Tue Aug 29, 2017 7:58 pm
Ok, I found that the issue was related to the size of the labels that describe the pie chart itself. If the label is shorter, the chart size increased. Still wish there was a way to manually set this because even so the chart could be larger within the space of the component's panel.
Post by Yeray » Thu Aug 31, 2017 8:12 am
I've checked it has the same behaviour in VCL and FMX. The CircleRect is adjusted to fit the Marks.
If you don't want this to happen, you can hide the Marks and draw them manually at OnAfterDraw event or using TAnnotationTools.
