I am investigating the possibility to have dual X scales on a plot (attached is an example), is this something that TChart supports?
Thank you very much for your time
Dual scale on plot
Dual scale on plot
- Screenshot_1.png (26.99 KiB) Viewed 8688 times
Re: Dual scale on plot
One possibility could be to use both Horizontal axes (Top and Bottom) as in the following example:
Another similar possibility could be to use a SubAxis. Ie:
procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis; Series: TChartSeries;
ValueIndex: Integer; var LabelText: string);
if Sender = Chart1.Axes.Bottom then
LabelText:= FormatFloat('#,##0', StrToFloatDef(LabelText, 0) / 10);
Chart1.View3D:=False;
Chart1.Legend.Visible:=False;
Chart1.MarginBottom:=10;
with Chart1.AddSeries(THorizLineSeries) as THorizLineSeries do
FillSampleValues;
HorizAxis:=aBothHorizAxis;
Chart1.Axes.Bottom.OtherSide:=True;
Chart1.Axes.Bottom.Grid.Visible:=False;
Chart1.Axes.Bottom.Ticks.Visible:=False;
Chart1.Axes.Bottom.MinorTicks.Visible:=False;
if Sender = Chart1.Axes.Top.SubAxes[0] then
LabelText:= FormatFloat('#,##0.##', StrToFloatDef(LabelText, 0) / 10);
FillSampleValues;
HorizAxis:=aTopAxis
with Chart1.Axes.Top.SubAxes.Add do
Axis.Visible:=False;
LabelsFont.Name:=Chart1.Axes.Top.LabelsFont.Name;
Hello Yeray,
Thank you very much for your prompt reply, I will definitely give it a try
John
John
