Binding Gantt
Philippe
Binding Gantt
Post by Philippe » Mon Sep 05, 2016 12:08 pm
Dear Sir,
I want to bind data to a chart gantt in order to have :
- Start Date
- End Date
- Y value
- Color
- Label
I tried this solution without success :
 public class GanttData
        public DateTime Start { get; set; }
        public DateTime End { get; set; }
        public int Y { get; set; }
        public string Label { get; set; }
        public Color Color { get; set; }
          public MainWindow()
            List<GanttData> lstData = new List<GanttData>();
            GanttData data1;
            data1 = new GanttData();
            data1.Color = Colors.Red;
            data1.Start = DateTime.Today;
            data1.End = data1.Start.AddDays(3);
            data1.Label = "Un";
            data1.Y = 1;
            lstData.Add(data1);
            data1.Color = Colors.Green;
            data1.Start = DateTime.Today.AddDays(1);
            data1.End = data1.Start.AddDays(1);
            data1.Label = "Deux";
            data1.Y = 2;
            lstData.Add(data1);
            tChart.Aspect.View3D = false;
            tChart.Header.Text = "Gantt MultipleNextTasks";
            tChart.Legend.Visible = false;
            Gantt gantt = new Gantt(tChart.Chart);
            gantt.ConnectingPen.Visible = false;
            gantt.LabelMember = "Label";
            gantt.Add(lstData);
What is wrong ?
Could you please help me ?
Thank you
Philippe
Re: Binding Gantt
Post by Christopher » Tue Sep 06, 2016 11:03 am
Hello Philippe,
Philippe wrote: What is wrong ?
Of course. Your class should look like this:
    public double Start { get; set; }
    public double End { get; set; }
which you can consume like this:
      GanttData data1;
      data1.Color = Color.Red;
      data1.Start = DateTime.Today.ToOADate();
      data1.End = DateTime.FromOADate(data1.Start).AddDays(3).ToOADate();
      data1.Label = "Un";
      data1.Y = 1;
      lstData.Add(data1);
      data1.Color = Color.Green;
      data1.Start = DateTime.Today.AddDays(1).ToOADate();
      data1.End = DateTime.FromOADate(data1.Start).AddDays(1).ToOADate();
      data1.Y = 2;
      lstData.Add(data1);
      tChart1.Header.Text = "Gantt MultipleNextTasks";
      Gantt gantt = new Gantt(tChart1.Chart);
      gantt.ColorMember = "Color";
      gantt.StartValues.DataMember = "Start";
      gantt.EndValues.DataMember = "End";
      gantt.YValues.DataMember = "Y";
      gantt.DataSource = lstData;
Philippe
Re: Binding Gantt
Post by Philippe » Tue Sep 06, 2016 12:57 pm
Dear Christopher,
Thank you very much for your reply.
I applied your code but the result is wrong about the date displayed.
Is it possible also to insert mark inside, different of label ?
Thank you
Philippe
Re: Binding Gantt
Post by Christopher » Tue Sep 06, 2016 4:46 pm
Hello Phillippe,
Many apologies for not seeing that issue earlier - I have added it to our ticket tracker with id=1621 and have already resolved it, meaning that a resolution to this problem will be found in the next maintenance release, due out in the middle of this month. I'm afraid to say that there is no workaround available to this issue.
Philippe
Re: Binding Gantt
Post by Philippe » Wed Sep 07, 2016 7:43 am
Dear Christopher,
No problem, until the release I resolved in this way :
           foreach (GanttData data in lstData)
                gantt.Add(data.Start, data.End, data.Y, data.Label, data.Color);
Is it possible to have the Marks with different value ?
How to do it ?
Thank you
Philippe
Re: Binding Gantt
Post by Christopher » Wed Sep 07, 2016 9:23 am
Hello Phillippe,
You always have the option to do something like this:
      GanttData data1;
      DateTime date = DateTime.Today;
      for (int i = 0; i < 3; i++)
        data1.Start = date;
        date = date.AddDays(3);
        data1.End = date;
        data1.Label = "Un " + ((i > 0) ? i.ToString() : "");
        data1.Y = 1;
        lstData.Add(data1);
      date = DateTime.Today.AddDays(1);
        data1.Start = date;
        data1.End = date;
        data1.Label = "Deux " + ((i > 0) ? i.ToString() : "");
        data1.Y = 2;
        lstData.Add(data1);
      gantt.Marks.Visible = true;
which will give you the following chart:
Philippe
Re: Binding Gantt
Post by Philippe » Wed Sep 07, 2016 1:16 pm
Christopher,
Yes, but the first 'Mark' value is the same of the Label !
No other possibilities to avoid this ?
Thank you
Philippe
Re: Binding Gantt
Post by Christopher » Wed Sep 07, 2016 3:06 pm
Hello Phillippe,
Yes, you can use Custom Labels, e.g.
      GanttData data1;
        data1.Start = date;
        data1.End = date;
        data1.Y = 1;
        lstData.Add(data1);
        data1.Start = date;
        data1.End = date;
        data1.Y = 2;
        lstData.Add(data1);
      tChart1.Axes.Left.Labels.Items.Add(1, "Uno");
      tChart1.Axes.Left.Labels.Items.Add(2, "Dos");
which gives me:
