Horiztal Bar Top Axis and Custom Y axis
Hi
I am trying to achieve this. I am facing below challenges
1)Can i show a custom y axis as you can see in image little *Red* V icons
2) Also is there a way i can shade gray couple horizontal bars e.g i want to shade alternate 5 bars
This is i am able to achieve.
- graph-loan-cohort-progess.png (13.87 KiB) Viewed 17179 times
- Guru
Re: Horiztal Bar Top Axis and Custom Y axis
Very roughly, you could start by something a little like this:
Steema.TeeChart.Styles.HorizBar hBar;
Steema.TeeChart.Tools.GridBand band;
hBar = new HorizBar(tChart1.Chart);
hBar.FillSampleValues(20);
hBar.Marks.Visible = false;
band = new GridBand(tChart1.Chart);
band.Axis = tChart1.Axes.Left;
band.Band1.Color = Color.White;
band.Band2.Color = Color.LightGray;
tChart1.Panel.MarginLeft = 10;
Axis leftAxis = tChart1.Axes.Left;
leftAxis.Increment = 5;
leftAxis.AxisPen.Visible = false;
leftAxis.Labels.Font.Color = Color.Transparent;
leftAxis.Ticks.Visible = false;
leftAxis.MinorTicks.Visible = false;
private void TChart1_AfterDraw(object sender, Graphics3D g)
g.Pen.Color = Color.Red;
g.HorizontalLine(0, tChart1.Axes.Bottom.IStartPos, tChart1.Axes.Left.IStartPos);
g.TextOut(20, tChart1.Axes.Left.IStartPos - 12, "text");
int fourthBar = hBar.CalcYPos(4);
g.Brush.Color = Color.Red;
g.Triangle(new Point(30, fourthBar), new Point(40, fourthBar), new Point(35, fourthBar + 10), 0);
Thanks Chris for your help.
Is there a way i can cover exactly 5 bars by gridband. As of now Gridband start middle of ticks
Also i am not able to get rid of bottom axes and the spaces highligted in Red
Note: Left Axis ticks are temporary
Chart chart = param.ChartInstance;
TChart tchart = param.TeeChart;
tchart.AfterDraw += tchart_AfterDraw;
tchart.Aspect.View3D = false;
chart.Axes.Custom.Clear();
for (int i = 0; i < 3; i++)
Steema.TeeChart.Styles.HorizBar loanBar = new HorizBar(chart);
// loanBar.BarHeightPercent = 100;
//Bar mstarForecastedLosses = new Bar(chart);
//Bar mstarBearishLossesBar = new Bar(chart);
loanBar.FillSampleValues(20);
//mstarForecastedLosses.FillSampleValues(4);
//mstarBearishLossesBar.FillSampleValues(4);
loanBar.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
// loanBar.SideMargins = false;
loanBar.Legend.Visible = false;
loanBar.Marks.Visible = false;
// mstarForecastedLosses.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
// mstarBearishLossesBar.MultiBar = Steema.TeeChart.Styles.MultiBars.Stacked;
loanBar.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Left;
loanBar.HorizAxis = Steema.TeeChart.Styles.HorizontalAxis.Top;
chart.Header.Visible = false;
// chart.Panel.Color = Color.Blue;
// chart.Panel.BorderRound = 5;
//chart.Panel.MarginBottom = 0D;
//chart.Panel.MarginLeft = 4.0D;
//chart.Panel.MarginRight = 0D;
//chart.Panel.MarginTop = 0D;
//chart.Panel.MarginUnits = Steema.TeeChart.PanelMarginUnits.Pixels;
Axis top = new Axis(true, false, chart);
chart.Axes.Custom.Add(top);
top.Grid.Visible = true;
band = new GridBand(chart);
band.Axis = tchart.Axes.Left;
tchart.Panel.MarginLeft = 7;
Axis leftAxis = tchart.Axes.Left;
leftAxis.Labels.Font.Color = Color.Blue;
leftAxis.Ticks.Visible = true;
leftAxis.MinorTicks.Visible = true;
leftAxis.Grid.Visible = true;
Axis bottomAxis = tchart.Axes.Bottom;
bottomAxis.AxisPen.Color = Color.Transparent;
bottomAxis.AxisPen.Visible = false;
bottomAxis.Labels.Font.Color = Color.Transparent;
bottomAxis.Ticks.Visible = false;
bottomAxis.MinorTicks.Visible = false;
bottomAxis.Grid.Visible = false;
- graph-loan-cohort-progess.png (12.26 KiB) Viewed 17165 times
- Guru
You're very welcome.
Possibly the quickest way to achieve this is again to draw elements on the chart, e.g.
tChart1.Axes.Left.Visible = false;
tChart1.BeforeDrawAxes += TChart1_BeforeDrawAxes;
private List<int> val = new List<int>();
private void TChart1_BeforeDrawAxes(object sender, Graphics3D g)
val.Clear();
for (int i = 1; i < hBar.Count; i+=5)
double middle = (hBar.YValues[i] - hBar.YValues[i - 1]) / 2.0;
val.Add(hBar.CalcYPosValue(hBar.YValues[i - 1] - middle));
Rectangle r;
for (int i = 1; i < val.Count; i++)
Color col = i % 2 == 0 ? Color.White : Color.LightGray;
g.Brush.Color = col;
g.Pen.Color = col;
r = Utils.FromLTRB(tChart1.Axes.Bottom.IStartPos, val[i - 1], tChart1.Axes.Bottom.IEndPos, val[i]);
g.Rectangle(r);
Legend and Chart top is overlapping , Also grid lines are not showing from top axis
private void SetCommonProperties(ChartBuilderParam param)
tchart.Legend.Alignment = Steema.TeeChart.LegendAlignments.Top;
tchart.Legend.DrawBehind = false;
tchart.Legend.Pen.Visible = false;
tchart.Legend.Shadow.Visible = false;
tchart.Legend.Transparent = true;
tchart.Legend.VertMargin =55;
tchart.Legend.CustomPosition = true;
tchart.Legend.Top = 10;
tchart.Legend.Left = 30;
tchart.Axes.Automatic = true;
public ChartBuilderParam BuildTopLoansCohortChart( ChartBuilderParam param)
SetCommonProperties(param);
// tchart.AfterDraw += tchart_AfterDraw;
GridBand band = new GridBand(chart);
leftAxis.IncrementOffset = 0;
leftAxis.Grid.Visible = false;
leftAxis.MinimumOffset = 0;
Axis topAxis = tchart.Axes.Top;
topAxis.Chart = chart;
topAxis.Grid.Visible = true;
topAxis.Grid.DrawEvery = 2;
topAxis.Grid.Fill.Color = Color.Blue;
Random rnd = new Random();
for (int k = 1; k <= 20; k++)
loanBar.Add(rnd.Next(100000,10000000));
return param;
- Guru
Would you please be so kind as to retouch your example so I can compile and run it here? I'm afraid I do not have access to your ChartBuilderParam object.
here is the source code - https://github.com/dekajp/DealViewChartApp
- Guru
Thank you for your code. The problem can be corrected by adding one line to SetCommonProperties():
The reason the MarginTop is necessary is because you have set CustomPosition to true.
tchart.Panel.MarginTop = 10;
Thank You , this worked
