Add image in Series instead of symbols.
SenSeo
Post by SenSeo » Mon May 09, 2016 10:16 am
Right now we are using the symbols to draw a chart. We would like to customize the image instead of tee chart symbols. Also, the same symbol should be display in the legend section too. Is it possible to customize our own icon? If so, please share some sample code.
Thanks!
Re: Add image in Series instead of symbols.
Post by Yeray » Mon May 09, 2016 12:46 pm
SenSeo wrote:We would like to customize the image instead of tee chart symbols
You can set a series format to use an image as brush with the code below. The pointer style will still be used to draw the shapes:
series1.pointer.format.image.url="images/metal.jpg"; //series1 is a Tee.PointXY
SenSeo wrote:Also, the same symbol should be display in the legend section too.
The solution is very similar to the one here.
    Chart1.legend.symbol.oldSymbolDraw = Chart1.legend.symbol.draw;
    function tryHover(series,index) {
        if (series.hover.enabled) {
            var sv=Chart1.legend.showValues();
            if ((sv && (series.over==index)) ||
                    ((!sv) && (series.over>=0)))
                return series.hover;
        return null;
    Chart1.legend.symbol.draw=function(series,index,x,y) {
        var f=this.format=new Tee.Format(Chart1);
        var c = Chart1.ctx, fhover=tryHover(series, index), old=f.fill, olds=f.stroke;
        if (series.pointer.format.image.url != "")
            f = series.pointer.format;
            f.fill= series.legendColor(index);
        c.z=-0.01;
        switch (series.pointer.style) {
            case "triangle": {
                y = y-this.height*0.5-1;
                f.polygon([new Point(x+this.width*0.5,y),
                    new Point(x+this.width,y+this.height),
                    new Point(x,y+this.height)]);
                break;
            case "ellipse": {
                f.ellipse(x+this.width*0.5, y, this.width, this.height);
                break;
            default: {
                this.oldSymbolDraw(series,index,x,y);
                break;
        f.fill=old;
        f.stroke=olds;
SenSeo
Post by SenSeo » Tue May 10, 2016 6:11 am
Thanks for your response. Its working like a charm.
SenSeo
Post by SenSeo » Wed May 11, 2016 1:17 pm
The square border is displaying for the customized image in the chart. How to remove the square border from the customized icon? Please refer the attached image for the reference.
Post by Yeray » Thu May 12, 2016 9:13 am
I have slightly modified the symbol.draw function to also use the series stroke. Ie:
    var series1 = Chart1.addSeries(new Tee.PointXY);
    series1.addRandom(10);
    series1.pointer.style="ellipse";
    series1.pointer.format.stroke.fill = "";
    var series2 = Chart1.addSeries(new Tee.PointXY);
    series2.addRandom(10);
    series2.pointer.style="ellipse";
    series2.pointer.format.image.url="images/wood.jpg";
        var c = Chart1.ctx, old=f.fill, olds=f.stroke;
        if (series.pointer.format.image.url != "") {
            f._img = series.pointer.format.image;
            f.stroke = series.pointer.format.stroke;
        c.z=-0.01;
            case "triangle": {
                break;
            case "ellipse": {
                break;
            default: {
                break;
        f.fill=old;
        f.stroke=olds;
