Delphi Seattle: Enable High-DPI results than expected
TestAlways
Post by TestAlways » Thu Feb 18, 2016 12:52 am
In working with Seattle, if "Enable High-DPI" (in Project/Options/Application) is checked, Annotations' text will appear small
(it is a little hard to see here unless you compare the annotation font against the axis label font--it is smaller, but should be the same size, or see that the annotations above take up less width than the annotations below).
But if I change it so that it is unchecked, it appears normal size:
I much prefer the first image (much cleaner), but the Annotation text is too small.
Is there a way to get the annotation text to not change its size based on DPI?
Ed Dressel
Re: Delphi Seattle: Enable High-DPI results than expected
Post by Yeray » Thu Feb 18, 2016 10:01 am
Hello Ed,
Can you please arrange a simple example project we can run as-is to reproduce the problem here?
TestAlways
Post by TestAlways » Thu Feb 18, 2016 3:06 pm
(Thanks for your patience on posting this in the wrong group).
I have attached a demo. Click in the chart to add color bands and annotations.
To see the difference, I compiled with the DPI settings checked and unchecked and renamed the EXE. I then ran the program on my Dell XPS 13. (I could not see it on my development computer).
Ed Dressel
Selection Point 3d.zip
(7.08 KiB) Downloaded 266 times
Post by Yeray » Fri Feb 19, 2016 10:34 am
Hello Ed,
TestAlways wrote:(Thanks for your patience on posting this in the wrong group).
No problem! I've moved it to the according forum now.
We'll revise the issue and we'll tell you something asap.
TestAlways
Post by TestAlways » Fri Feb 19, 2016 3:16 pm
Yeray wrote:We'll revise the issue...
I'm not sure I understand what that means. Could you clarify?
Ed Dressel
Post by Yeray » Fri Feb 19, 2016 3:24 pm
Hi Ed,
TestAlways wrote:I'm not sure I understand what that means. Could you clarify?
Yes. We'll check what's wrong, we'll see if we can do something to improve that, we'll investigate where the problem comes from...
TestAlways
Post by TestAlways » Wed Feb 24, 2016 8:24 pm
Just checking that you could reproduce the issue?
Ed Dressel
Post by Yeray » Thu Feb 25, 2016 9:20 am
Hello Ed,
Yes, I've reproduced the problem so I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1447
