Setting Location of Labels in Bubblechart
Roland
Post by Roland » Fri Apr 24, 2015 3:25 pm
What is the best way - if there is any - to position labels of overlapping bubbles, like in the attached example?
Is there any possibility to configure the chart in a way that such intersection as in the attached image is avoided?
label problem2015-04-24_172153.png (1.69 KiB) Viewed 11081 times
Best regards
Roland
Re: Setting Location of Labels in Bubblechart
Post by Yeray » Mon Apr 27, 2015 9:13 am
Hi Roland,
I'm not sure to understand how are you exactly setting that chart. Do you have several bubbles with the same X and Y position?
In that case, you may want to try to implement some anti-overlapping algorithm:
http://www.teechart.net/support/viewtop ... 785#p64785
Roland
Post by Roland » Fri May 08, 2015 9:02 am
Hi Yeray.
Yes - what you describe is my problem and anti-overlapping should solve it. Thanks for the link, I will have a look into it.
Best regards
Roland
