If a TeeChart component that is on a hidden page of a tab control becomes active but using the TabControl's "SetActiveTabWithTransition" with "TTabTransition.Slide".
Using the attached demo, make sure "TabItem1" is the selected tab at design-time; Run the app; click "Button2" to active "TabItem2" with the "Slide" animation; The App will hang.
If the "Chart1" is made visible by either setting "TabItem2" as selected at design-time, or by clicking "TabItem2" directly at run-time, then the "slide" transition will work (won't hang the app) from then on.
I have an Mobile (iOS) app that was developed on XE3 that has multiple TeeChart components on pages of TabControls that use the slide transition to move between the tabs/pages. I converted/upgraded this project to XE4, XE5, and then to XE6 with no problems.
In hindsight, I've always noticed a curious pause (1 to 2 secs) the *first* time a page with a TeeChart component is "slide" animated in - it's been there since the first version using XE3.
XE7: TChart on FMX TabControl hangs using "slide" animation
- TeeChartErrorXE7.zip
- Simple project that quickly shows the hang behavior.
- (58.48 KiB) Downloaded 1209 times
Re: XE7: TChart on FMX TabControl hangs using "slide" animation
I could reproduce the problem and we're investigating it.
We'll be back to you here asap.
I've reproduced the problem and I've seen the error is a bit different with the actual sources we use here. I've added a ticket to the public tracker you can follow:
http://bugs.teechart.net/show_bug.cgi?id=974
Hi again,
Just to let you know we just fixed it in the internal sources we have here so the next maintenance release should allow you to do this without problems.Yeray wrote:http://bugs.teechart.net/show_bug.cgi?id=974
Excellent! Thank you for your attention to this. Could you give me a rough guess as to when that maintenance release will be available?
However, I see you are a source code customer so I'll send a link to the latest beta sources to the mail account you have registered in this forum.
I'm afraid I can't tell you this.dolson wrote:Could you give me a rough guess as to when that maintenance release will be available?
