Chart Quality issue between Delphi 2010 TeeChart and latest
Taz Higgins
Post by Taz Higgins » Thu Aug 14, 2014 5:41 pm
Hello
We were using Delphi 2010 with the full VCL edition of TeeChart this worked fine
We have now updated to Delphi XE 5 with the latest version of TeeChart and the quality of the charts is now worse
Please see this image image http://www.stcenergy-online.com/dev/narrow.png
2 bars which were seperate are now merged into 1 bar
If I make the charts wider which is not an option it looks better but still not as good as before
Please see this image http://www.stcenergy-online.com/dev/wide.png
Has anyone come across any issue like this?
The projects are at http://www.stcenergy-online.com/dev/chartproblem.zip for Delphi XE5 and http://www.stcenergy-online.com/dev/delphi2010chart.zip for Delphi 2010
The search paths may need modifying
Cheers
Paul
Taz Higgins
Re: Chart Quality issue between Delphi 2010 TeeChart and latest
Post by Taz Higgins » Thu Aug 14, 2014 5:56 pm
PS I work with Tarry!
ControlPanel
Post by ControlPanel » Thu Aug 14, 2014 8:30 pm
We have had issues with line graphs looking blurry with new versions of both the VCL and .net versions.
It turned out that the newer versions use some kind of antialias/smoothing when drawing (by default!).
Could this be the problem in your case?
Try to draw a diagonal line and see if it gets smoothened.
Taz Higgins
Post by Taz Higgins » Fri Aug 15, 2014 5:35 pm
How can I turn anti aliasing off?
johnnix
Post by johnnix » Sat Aug 16, 2014 5:24 pm
Try to double click on the chart, select 3D on the left panel of the Editor and from the Render tab at the right select GDI
Post by Yeray » Mon Aug 18, 2014 11:06 am
Hello Paul,
I see you opened a thread with the same question at StackOverflow.
I agree with the other answers written both here and there.
As you can read in several threads in these forums (ie here and here) we switched from GDI to GDIPlus as default engine recently (from v2013.08) but you can still activate GDI as mentioned in the threads mentioned above.
If activating GDI again doesn't allow you to return to the old behaviour, please tell us what exact TeeChart version were you using with Delphi 2010.
