Cursor Tool
Turc
Cursor Tool
Post by Turc » Mon Oct 07, 2013 4:22 pm
I Initialize the cursor Tool:
cursorTool = new CursorTool(this.getChart());
cursorTool.setActive(false);
cursorTool.setFollowMouse(true);
cursorTool.setStyle(CursorToolStyle.VERTICAL);
cursorTool.getPen().setStyle(DashStyle.SOLID);
When the user clicks on the graph (mouseClicked MouseEvent), then I enable the cursor tool:
if(!cursorTool.getActive())
      cursorTool.setXValue(e.getX());
      cursorTool.setActive(true);
The issue that I'm having is that the vertical cursor line does not appear when the user clicks on the chart, but only after the user moves the mouse. Is there any way that the vertical line can show up upon a mouse click instead of a mouse movement once it's enabled?
Re: Cursor Tool
Post by Yeray » Tue Oct 08, 2013 10:42 am
Hello Turc,
Not the MouseEvent gives you the Mouse pointer position in pixels, through the getX()/getY() functions, while the CursorTool setXValue() function expects to receive a Value on the axis scale as a parameter.
So you gave to convert the e.getX() value to the Axis scale. This seems to work fine for me here:
cursorTool.setXValue(tChart1.getAxes().getBottom().calcPosPoint(e.getX()));
Turc
Re: Cursor Tool
Post by Turc » Tue Oct 08, 2013 12:48 pm
Thank you.
